changing the Diff gearing
Old Apr 5, 2007 | 05:22 PM
hornet7's Avatar
hornet7
Default changing the Diff gearing
I'm considering replacing the standard (2.42) gearing in my Coupe to 3.79's. What do I expect to gain from this change in performance and fuel mileage and is it worth it?
Old Apr 5, 2007 | 05:46 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default ???
Is your car a 6spd or Auto. If it's an Auto it's a 2:73. If it's a 6spd it's 3:42. Do you want to go to 3:73 or 3:90's?
I put 4:10's in my car (from 3:42's) and my gas mileage didn't chage too much (about 1mpg loss).
Bob K.
Old Apr 5, 2007 | 05:50 PM
hornet7's Avatar
hornet7
Default diff change
My car is a 6 speed, the gearing is 3.42 and I thinking of going to 390's.
Old Apr 6, 2007 | 04:45 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Go with 4.10's, you will be happy you did.
Clayton from Las Vegas
Old Apr 6, 2007 | 08:32 AM
pimpjames's Avatar
pimpjames
As much as I hate to be "That guy" A search would have given you your answers with lots of differnet opinoins from previous posts.
Old Apr 6, 2007 | 09:30 AM
94legaleagle's Avatar
94legaleagle
Couple things - the standard gearing is 2.73, not 2.42; and you would be installing 3.73's, not 3.79's
Also, just so you know, you don't just swap the gears w/in the pumpkin/carrier like you did in old cars - instead, you swap out your stock carrier for a carrier w/ the gears that you want -
Also, if you are going to do it, save yourself some $$$ and install a Torque Converter at the same time - gears and T/C will compliment each other and the labor is the exact same to swap them - therefore, while you are working in that area, do BOTH.
IMHO, 3.73's w/ a SS3200 or SS3600 stall are the PERFECT combination!
Old Apr 6, 2007 | 10:04 PM
jordanfd's Avatar
jordanfd
Old Apr 7, 2007 | 12:46 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
That would be pretty hard to do. He has a manual transmission. Again, go with the 4.10's. There are a lot of similar posts like yours and the majority say go with 4.10's.
Old Apr 7, 2007 | 01:25 AM
00'Vette's Avatar
00'Vette
I have a 6sp and I swapped from my 3:42's to 3:90's and love them to death. My car has just over 560rwhp and that gear is perfect for them. It puts the RPM's in the sweet spot every shift.
Go with the 3:90's!!!
Old Apr 7, 2007 | 01:41 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I have tried both 4.10s and 3.90s and I like 3.90s much much better.
Old Apr 7, 2007 | 11:07 AM
Mike Mercury's Avatar
Mike Mercury
I imagine the 3.90's are a little bit more controllable, especially with launching.
Of course - if one is willing to mod the rear suspension, and put on proper tires when at the track... I can believe a skilled driver can control the 4.10's as well.
Old Apr 7, 2007 | 11:56 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
4.10s for a 6-speed
Old Apr 7, 2007 | 12:55 PM
Lusky's Avatar
Lusky
Over 500 Rwhp Get 3.90's
Under 500 Rwhp Get 4.10's
Old Apr 8, 2007 | 02:07 AM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Over 500 rwhp, I think 3.73's and over 600 rwhp, stay with the 3.42's
Old Apr 8, 2007 | 03:25 AM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
i have 3.90's in my car and love them. the mn6 with a 3.90 is a great all around combo.
Old Apr 8, 2007 | 04:28 AM
FactoryRaceCar
JBSBlownC5 (Joel) is running 3.73 with 700+rwhp and has touched 200 MPH many times.
Old Apr 8, 2007 | 04:31 AM
FactoryRaceCar
Yes Tim, 3.90s are much more controllable and keep you in powerband much better than 4.10s which are just over kill for anything over 500rwhp. I dont drag race. I am more of a roadcourse and street person and they work perfect for my application. I am currently at 650ish rwhp and love my 3.90s. Its like in boost upto 3k RPMs till the real supercharger boost hits
To changing the Diff gearing
Old Apr 8, 2007 | 09:48 AM
EMDExpress's Avatar
EMDExpress
I went with 3:73 that has 432 rwhp and I found it to be a great compromise between power and the ability to keep rpms low at cruise in sixth gear. A;most stock quite at cruise and screaming loud at ful pedal and high rpm.
Old Apr 8, 2007 | 11:58 AM
NOS500's Avatar
NOS500
I have a stock engine, and I installed the 4.10's and I love them. The 4.10's keep the rpms in the perfect spot. The gas mileage has gone down about 1 mpg so its not too bad.
Old Apr 8, 2007 | 10:19 PM
94legaleagle
Um, Uh, DuH . . . yep, I should've read ALL of the posts more closely before I posted - thanks for catching this
