changing the Diff gearing
Old Apr 8, 2007 | 10:58 PM
tiojames's Avatar
tiojames
Originally Posted by hornet7
My car is a 6 speed, the gearing is 3.42 and I thinking of going to 390's.
Don't forget to post your 3:42's here in the forum. The guys with autos will buy them. Depending on the mileage, you can get $350-500 for them to help offset the cost of a new diff-$1100-1200. A new diff is the way to go because you get new bearings, posi, etc.
Old Apr 9, 2007 | 01:20 PM
TYSON1997's Avatar
TYSON1997
If you are going to buy a new rear end instead of just swapping gears I would just spend the money on an m12 tranny. You would be much happier. You have the lower gears where you need them but your 5,6th gears are still for good gas mileage.
Old Apr 9, 2007 | 01:27 PM
Mike Mercury's Avatar
Mike Mercury
hmmm... interesting idea.
Old Apr 9, 2007 | 04:05 PM
hornet7's Avatar
hornet7
Default Gearing
Currently my Transmission is being rebuilt with performance (Z06) upgrades. I plan on changing the gearing to match my lust for Freeway on-ramp speeds. If this is the same as an M12, we're good to go. If not, I will need to dig further into my upgrade. My local Corvette specialty is doing the work. My power train upgraded started with my 1st and 2nd Synchros giving me problems. So, I also planned on replacing my Clutch and pressure plate while the car was in the shop. This upgrade is growing to replace and/or upgrade to performance parts in the diff as well. So, I've replaced my Clutch, Transmission parts, and Diff gear ratio (3.79) and any obviously warn components. Any suggestion that I've missed?
Old Apr 9, 2007 | 04:41 PM
wettvette's Avatar
wettvette
Originally Posted by NOS500
I have a stock engine, and I installed the 4.10's and I love them. The 4.10's keep the rpms in the perfect spot. The gas mileage has gone down about 1 mpg so its not too bad.
should be how the car left the factory new
Old Apr 9, 2007 | 05:07 PM
fdxpilot's Avatar
fdxpilot
One more time. I'll speak slowly.
There is no such thing as a 3.79 gear ratio for a Gertrag Corvette rear end.
Any shop that tells you so does not know what they're doing. Your choices are 2.73 (stock A4,) 3.15 (opt A4,) 3.42 (stock MN6,) 3.73, 3.90, and 4.10.
Old Apr 9, 2007 | 05:09 PM
hornet7's Avatar
hornet7
I'll check my paperwork
Old Apr 9, 2007 | 07:35 PM
robert123's Avatar
robert123
Are you sure you have a c5 vette?
Old Apr 9, 2007 | 07:36 PM
robert123's Avatar
robert123
Old Apr 9, 2007 | 09:14 PM
ndirishr1's Avatar
ndirishr1
Go all the way to 4.10s.
You'll hate yourself in the morning if you don't!
Old Apr 9, 2007 | 11:52 PM
mtm87tx's Avatar
mtm87tx
if i had a MN6 i would do 4.10s
but since i have a MN12 i am leaning towards 3.90s
Old Apr 10, 2007 | 12:20 AM
Max@Cartek's Avatar
Max@Cartek
+1 on the 4.10s
Max
