Any tips on replacing the steering wheel position sensor?
Old Sep 13, 2010 | 01:33 PM
  #81
buxgrad91's Avatar
buxgrad91
1st Gear
Just a note not discussed in the disassembly...the knee bolster removal: there are four screws, 2 under the dash(easily seen) and 2 up top(one is behind the deck lid button left of steering wheel- merely pry it out to reveal the screw ) and the other is behind the small air hole just to the left of the ignition switch..pry it off too to reveal the screw. As mentioned earlier, the radio bezel must be loosened too. The nuts for this are under the traction control button(pry off) and there are also 2 screws in the ashtray, 1 visible and the other behind the ashtray itself(pull-out). You must also loosen and remove the two nuts in the armrest. Open the lid and the two are under 2 black tabs toward the back. Pretty easy job...1.5 hours and you have it licked. Make sure you are loosening the 15mm side of the steering bolt .. stupid me spent 20min trying to loosen the 1/2" side... live and learn I guess. Good Luck!
Old Nov 6, 2010 | 09:51 PM
  #82
jamies z06's Avatar
jamies z06
did this replacement in lessthan 2 hours what a great forum for all there little tricks, dealer wanted 600 + plus parts for this fix
Old Nov 19, 2010 | 09:39 PM
  #83
Zo6TT's Avatar
Zo6TT
anyone have a pic of the steering lock bypass? im not sure if i have this or not and would like to know before i start this...sucks cuz im a little paranoid to drive the car in fear of the brakes or traction system locking up...someone said they were on the highway doing 70 and the tcs activated the front drivers side brake and he almost crashed. ??? sucks cuz i dont have many days left to drive her before it gets too cold out and maybe snow
Old Nov 23, 2010 | 09:22 PM
  #84
agood1's Avatar
agood1
Hate to dig up an old thread, But here is a new twist.
This is what it should look like.....
This is what I found.......have no idea what happened. The sad part is, the SWPS that was on the car is still probably good, but I can't return the one I already bought to replace it.
Old Nov 24, 2010 | 11:41 PM
  #85
Zo6TT's Avatar
Zo6TT
so in that pic that green ring is broken near the top???(the one installed)
Old Nov 25, 2010 | 11:12 AM
  #86
agood1's Avatar
agood1
Yep, broken completely off.
Old Nov 29, 2010 | 02:42 PM
  #87
Zo6TT's Avatar
Zo6TT
88965543. Can someone please verify this is the right part number for my 04 zo6. Thanks
Old Nov 29, 2010 | 02:48 PM
  #88
Tracy's Avatar
Tracy
That's the part number that worked on my 2003 Z06, so I think you can assume it's good (00-04). That number has been referenced several times in this post. Also, see posts 1, 18, and 59-62.
Old Jan 9, 2011 | 08:38 AM
  #89
C1 Eire's Avatar
C1 Eire
I did this yesterday by following the instructions here. Thanks to everyone that took the time to post up the instructions.
Old Jan 15, 2011 | 01:36 PM
  #90
froggy47's Avatar
froggy47
Old May 15, 2011 | 01:39 AM
  #91
SilverC54me's Avatar
SilverC54me
Just did the replacement of the SWPS this morning. Took about 2hrs to complete. The worst part is getting the column out and back into the car without damaging the interior.
With the help of this thread it was an easy process of replacing the SWPS.
Gary
Old Aug 14, 2011 | 11:01 PM
  #92
Jackman's Avatar
Jackman
Default Steering column lock
I have checked all the forums and I don't see anything about a Steering column lock problem. Today I got a warning on my info center to service steering column lock. Any help out there?
Old Aug 14, 2011 | 11:41 PM
  #93
byronhunter's Avatar
byronhunter
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Aug 15, 2011 | 12:03 AM
  #94
Jackman's Avatar
Jackman
Thanks for the info Byron.
Old Aug 20, 2011 | 12:15 AM
  #95
Zeus-of-Boost's Avatar
Zeus-of-Boost
no more SES and dic codes for me. thanks to the help of you guys. i did remove the wheel and asses panel (no brainer) and i did remove the colunm. only part i had trouble with was getting the steering shaft back into the female shaft in the engine compartment. i couldnt have done it without the help of my wife. its just impossible to get the shafts lined up and push the steering shaft into place from inside the car. thanks again guys ,helped my 1287 and 1288 codes.
Old Mar 17, 2012 | 01:46 PM
  #96
Ironman433's Avatar
Ironman433
Default DISCONTINUED by GM - How Handy!!
I've been reading thru posts on this Steering Wheel Position Sensor for a while because my Active Handling System keeps becoming active when I take a corner unless I de-activate it and I get the warnings to Service Active Handling Soon. Looking at my DIC codes, I get the codes:
28-TCS - Traction Control System
H C1286 Steering Sensor Bias Malfunction
H C1287 Steering Sensor Rate Malfunction
I just discovered that this part is now discontinued by GM. Anyone happen to know where I can locate one of these GM Unicorns...?? After ordering two of these and paying for them online: Corvette Parts Worldwide.com and Corvette Specialties of California - they both informed me, as did 3 local Chevrolet dealers, that the part was now DISCONTINUED by GM!!
Old Mar 17, 2012 | 05:50 PM
  #97
Luweegy's Avatar
Luweegy
Corvette recycling in Utah. They should have it.Talk to Jason. Gm has discontinued a bunch of things for the C5.
To Any tips on replacing the steering wheel position sensor?
Old Mar 18, 2012 | 10:16 AM
  #98
sunchaser73's Avatar
sunchaser73
Does anyone know if the steering wheel position sensor for the 01-04 C5 is compatible with a 99?
Old Mar 19, 2012 | 08:11 PM
  #99
sunchaser73
Bump...anyone know if sensors are interchangeable between early and late C5s?
Thanks!
Old Apr 22, 2012 | 03:42 PM
  #100
98DC231's Avatar
98DC231
Sincere thanks to everyone who contributed to this thread, without the detailed instructions and pics, i likely would not have attempted it. Overall, it was extremely easy to do and solved my c1287 and c1288 dic codes.
