need help please look inside
The reason... there is a design flaw that affects 90+% of all C5's before '02 . The flaw causes the column to lock and remain locked no matter what you do... GM has attempted many fixes/recalls, but none work as well as the aftermarket bypass ( CLB)
see the sticky at the top of the tech section called steering column lock http://forums.corvetteforum.com/show....php?t=1015483
What lights are you talking about that keep coming on? Are you getting a message on the DIC ( driver information center) that says pull key and wait 10 seconds, or service column lock??? or are you talking about some other lights??
If you have a column lock fault the computer sends a message to the engine and won't let the car be driven over 2 mph...
if your answer is no how do i keep the message from coming on?
or is there a recall where i can just take it in? i just bought this car so i am not sure if the recall was already done on it!!!!!!!
thanks again
