Wandering in Steering
Old Apr 9, 2007 | 09:33 PM
GYM's Avatar
GYM
Cruising
Default Wandering in Steering
Looking at a 1998 Vette. Read in some article that in later years GM had changed front end parts because of wandering in the 1998. How bad is this problem?
Old Apr 9, 2007 | 10:19 PM
Bill Dearborn's Avatar
Bill Dearborn
To my knowledge all of the parts are the same. Wandering is due to tires and alignment. The run flats are more susceptible to wander and if you have a little toe out it is worse.
Bill
Old Apr 10, 2007 | 02:51 AM
Vette_Fan's Avatar
Vette_Fan
Mine's a 99. Seems like a crackling sound my steering wheel makes. The 4 corners are not all alink. The right/upper corner seems to be a little popped up. When I push it down with my thumb, the noise stops. As soon as I let go, it starts again.
Do I need to see the stealer (dealer) for this, or should I put in a screw driver and try to tighten the screw there. (I hope it doesn't interfare with the air bag, if I tighten it in)... I'm kinda lost here. Looking to read more articles on steering wheels wandering...
Old Apr 10, 2007 | 02:53 AM
DeeGee's Avatar
DeeGee
Is there any play in the steering when the car is stationary?
In my experience, the tires and pressures are the biggest influence on that issue. the OEM runflats are really prone to "tramlining". If you have aftermarket wheels or tires that are wider than OEM that may also affect it.
I fitted Michelin Pilot Sports and the improvement in handling was significant.
Old Apr 10, 2007 | 09:47 AM
rws.1's Avatar
rws.1
tramlining is caused by alignment and tire side wall stiffness and width....
The wider the tires, the more apt a car is to follow ruts in the road.
The stiffer the side wall (run flats) the more apt the car is to tramline.
To Wandering in Steering
