I'm contemplating removing the "lock ring" on my steering column, so I'll NEVER have any issues with the dreaded column lock up. I've removed a lot of steering wheels in the past, but never one with an airbag.
Has anyone done this, and other than the usual disconnect battery and/or remove airbag circuit fuse, any other extra precautions need to follow?
Leadfoot,
I'm doing mine now. Just got the air bag module off and I'm fabricating a steering wheel puller. Unfortunately you can't use a standard puller that I can find anywhere. Email me if you decide to dive in. I can share some of my findings as I disassemble mine.
John cscokd@gmail.com
I just located and purchased a steering wheel puller at Napa Auto Parts
You'll need the legs which are p/n 3510 $22.49, the puller which is p/n 2291 $19.09 and the lock plate compressor tool p/n 3509 $34.38. I'll let you know how it goes.
John
I got lucky and a great tech at the dealership came to my house and did it when I got my VE wheel........He charged me $15 I gave him $40.......great guy, conscientious and will do little jobs on the side for me.
Just got the steering wheel off and removed the lock plate. It went very smoothly with the right tools. Now to get the new lock plate from the dealer tomorrow. I think I'll take pics and do a detailed How To for us since I couldn't seem to find one. The airbag module really wasn't all that bad to remove. I don't think it's too risky or difficult as long as you remove the SDM fuse in the passenger footwell and then disconnect the yellow wire harness below the steering column. Just remove the two bolts from the rear of the steering wheel cover and the airbag module comes right out. There was a little trick to remove the wire connector from the back side of the airbag module. It's an odd 2-pin yellow connector. Lift the plastic lock prongs on top and then simply pry it straight out. The other thing that was a little confusing was removing the single wire horn connector. Don't pull it straight out. It actually twists and then simply pulls out.
Cheers,
John
any reason you arent just doing the CLB?? no steering wheel removal and it only takes 30 mins....just wondering
Guys, thanks for the input. I have a shop manual and have looked over the process. It didn't look too bad, however it always helps to talk to someone who's been down the road before you. Secondly, at least in the past, the factory manuals were somewhat "overstated" as to what actually had to be done. There were always some shortcuts to be found.
Pewter, I tried a CLB a couple of years ago. Installed it, but for some reason, it wouldn't hold the lock pin fully retracted, and I could both hear and feel the pin hitting the detents in the lock plate when I would turn the wheel. I immediately took it out. I know that many people swear by the CLB, but I'm not convinced that it's foolproof.
Just got the steering wheel off and removed the lock plate. It went very smoothly with the right tools. Now to get the new lock plate from the dealer tomorrow. I think I'll take pics and do a detailed How To for us since I couldn't seem to find one.....
Cheers,
John
John, EXCELLENT idea!
I purchased another lock ring in advance, in order to minimize down time. What I found is the center hub ot the ring has enough of a lip on the one side so you can grip it in a collet for a lathe. I was then able to use a cutting tool, and remove the OD of the lock ring, the part where the lock detents are...
Monday Update
I went to the dealer today to see about purchasing the new lock plate called out in the GM recall instruction. As it turns out, you can purchase the whole kit (P/N 89023816) for $134.00 but you cannot purchase just the replacement lock plate. I asked the parts guy to get the kit so I could inspect it. I was surprised that the replacement lock plate looks very different than the original. So I guess I'll modify my old one because I'm not about to spend that much for a kit that I don't really need especially the inferior K Harness. I'll post some pics of the modified lock plate shortly.
John
Can you not just buy the lock plate from an '04 auto? I think I have that part number at home. I agree that I would not pay that kind of money for a lock plate.
The replacement for my '01 was $12 plus shipping form an online GM dealer. It took me about 5 minutes, on the lathe, to cut off the OD with the detents
Monday Update
John
I would just cut the plate down on a grinder.
Can't you just remove the actuator altogether? The result would be the same no?
cannot remove the actuator in my opinion, but the grinder is still an option on the table I should check out the lock plate for an '04. That might work.
The original recall kits with the Harness K wiring harness in them, came with a small plate to replace the larger locking plate. You still need a plate in the column to cancel the turn signal cam and to maintain the proper spacing of components.
Since the later model automatics did not have the full sized locking plate, check with the dealer to see if you can order just the smaller plate that came on the automatics. I think it is the same as the one that comes in the recall kits.
(Cscokd-if you find you cannot buy just the smaller plate, I have an extra one that you can get for a lot less than $135)
I called the dealer today and asked about the plate for an '04 and the parts guy said there was no plate called out on the '04. So that sort of left me at a dead end. I think I'll just grind mine down. It doesn't look very difficult. Thanks for the offer Terry
