Help! Battery Drain issues
I was able to fix the battery drainage problem and the Right brake light problem. The dealer was right on both cases. I removed the drivers seat switch and the drainage dropped down to around 20 mA which I believe is typical with C5s. I also had to tear apart the consol and dash to replace the multifunction switch (basically the blinker stick) and somehow that solved the right brake light issue.
So I'm much happier now.
PROBLEMS FIXED...
I've been having all sorts of electrical problems... took it to a dealer and not to pleased with their diagnoses. I might spend some time to explain the whole situation later, but it'll be a long post.
Anyway, does anyone know the typical drain on a battery when it sits idle???
Mine goes to about 640 milliamps after about 3 minutes, then after around 10-15 minutes it drops down to 280 and stays there.
What should a good working 2001 Vette be? It's obviously not going to be 0, but it should be fairly low.
Also anyone with stuck window problems... the hammer trick works pretty well.
Has anybody measured this????
I've already gone through about 3-4 batteries. The Original, and a couple of Exide Orbitals.
The dealer says there is a short in the drivers seat switch (P/N 12135158). But I pulled the circuit breakers to both power seats and still received the same drain. Also from my experience with them. I'm not too confident in their abilities
Does anyone know where that part is located and what I have to do to replace it??? I've found the part for about 70 bucks just need to know where it is in the car.
My right side brake lights aren't working as well. Dealer says a multifunction switch in the steering column is the problem.
Also, I've already fixed the window problem... had to take apart the door panel and the speaker. Then I tapped the end of the regulator with a hammer while holding the down button. Dealer wanted to replace the regulator for $684. I fixed it for free
hth,
Sully
P.S. yes.... Bill Curlee is the expert here with this
hth,
Sully
I've just PM'd Bill, from info I've been gathering so far 20 mA drain in about 15 minutes is correct.
Like I said in the orignal post the dealer says its the drivers seat switch... but I pulled the fuses (it says circuit breakers, but its in the fuse box) under the passenger side floor, which disabled the power seats completly, but I still recieved the same drain.
I have another post in the general section if your interested
http://forums.corvetteforum.com/show....php?t=1672474
radio, seats, and windows.
Anything else you might know could be a culprit?
