Maf question
Old Apr 10, 2007 | 08:33 PM
rrw4's Avatar
rrw4
Default Maf question
Would changing mass airflow sensors from one car to another work? Both cars are 2000 corvettes. One is auto and one is manual. Is this possible? Is there any precautions or consequences? Thank you.
RRW4
Old Apr 10, 2007 | 08:57 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
This should not be a problem ,especially if both are from the same year. The sensor is preset and does not matter if its for an auto or stick.
Old Apr 11, 2007 | 07:03 PM
rrw4's Avatar
rrw4
Thanks nasty98.
Old Apr 11, 2007 | 07:30 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Originally Posted by rrw4
Thanks nasty98.
By the way if you remove the screen in the MAF you can pick up a few free ponies
Old Apr 12, 2007 | 09:57 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you remove the screen in the MAF, you may provide benefit to WOT performance BUT,,,,,,you may effect part throttle performance in a negative way!!!! Your fuel mileage may drop a little as you will effect you MAF calibration. Any time you change the air flow through the MAF, it effects the calibration! The ONLY way to really monitor the effect positive or negatively is by using tuning software like EFI LIVE or HP Tuners.
When your in WOT, you don't use the MAF calibration.
My 2 cents.
BC
Old Apr 12, 2007 | 10:34 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
RRW4
NOPE! No problem!
Thanks,Matt
To Maf question
