Bassani Headers
Old Apr 15, 2007 | 02:28 AM
SLPRC5's Avatar
SLPRC5
Default Bassani Headers
Pros and cons about Bassani long tube headers as far as performance?
Old Apr 15, 2007 | 09:43 AM
vettenuts's Avatar
vettenuts
Seeing as there has never been a true side by side comparison, hard to tell. I would think a swap to one of the more touted setups would net minimal gain.
A correctly tuned Tri-Y header is preferred by a lot of the road race guys and there a lot of good articles on them. After all the reading I did, I selected the Tri-Y design over the more traditional 4-1 design realizing I "might" have given up a few ponies up top (not fully convinced of this) but also may have gained a more favorable mid-RPM torque curve. The only down side to the Bassani's is they are not stainless (one reason I went with the QTP's) and there is a joint in the pipes (QTP's are one piece).
Here's a good read
Jack Burns Article on Try-Y Headers
Old Apr 16, 2007 | 04:49 PM
SLPRC5's Avatar
SLPRC5
Here's a good read
Very good reading. I have a set of Bassani headers on now and I'm happy with them...but the guy who tunned my car said they weren't the best and because of clamps that they leak...so far I have no leaks.
Of course he wanted to order a set of American Racing headers to gain more HP, but I think I'll stick with the Bassani until they wear out.
Again thanks for you much needed input...
SLPRC5
Old Apr 16, 2007 | 09:10 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
too many pieces, i have never seen a set other than in magazines
Old Apr 16, 2007 | 10:15 PM
Z064FUN's Avatar
Z064FUN
You're splittin' hairs. It sounds like the American Racing Headers are the best ones out right now. If I was buying a new set that is what I would get, but they aren't going to give you more than 5-7 hp max. That just isn't worth $2000. At that price you might want to start looking into a carb legal supercharger. Good luck
Jade
Old Apr 17, 2007 | 01:03 AM
RikkiC5's Avatar
RikkiC5
I 'm using Bassani Headers, excellent mid range under the curve horsepower. Most of the long tubes tend to create more HP at the upper RPM's. I have know leaks either and they come ceramic coated. The sound is great! Just my humble opinion.
Old Apr 17, 2007 | 07:30 AM
qwkz06's Avatar
qwkz06
No leaks, ceramic coated, great power under the curve.
Old Jan 18, 2010 | 06:12 PM
USCGREEL's Avatar
USCGREEL
I know this thread is dead, but mine leak. There is no point in having the joints on the headers...because when they are installed you cant even tighten the clamps that hold the joint together. I will have to pull off the header to put copper gasket on the sleeve joint, then tighten and reinstall.......why not just have one solid header 4-1. Also I have ceramic coating, but have surface rust on them (and it has not been grinded on or any other metal sitting on them). Not a very happy customer...called Bassani and they told me just keep applying the copper gasket sealant......No problem, I will just pull the headers off every year to do that.....waste of time. Ok im done ranting.
Old Jan 18, 2010 | 09:47 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I've seen one in person on a C5 in the shop on a lift.
The x-pipe had stock cats welded on, and the thought of multiple pipes on the primaries seemed like a stupid idea if you were to own the car for decades. Overall I thought it was the worst cluster f*** I'd ever seen.
The owner was getting Kooks installed. I could have bought that used set-up for a steal but I passed.
Old Jan 19, 2010 | 05:39 AM
vettenuts's Avatar
vettenuts
QTP did a much better job of executing the Tri-Y design and they did it in stainless. Unfortunately they are no longer made.
To Bassani Headers
