Radiator flush
Old Apr 15, 2007 | 01:13 PM
crause's Avatar
crause
Default Radiator flush
I am going to change the coolant soon because the guy I bought the car from said that he has never had it changed. Even though the car is 7 years old it only has 13000 miles. I know these cars have strange quirks so are there any warnings or suggestions before I start? Any recomendations for replacement fluid? Use drain plug or disconnect one of the rad. hoses? Original hoses, change or leave alone if they appear ok?
thanks in advance,
PAC
Old Apr 15, 2007 | 02:08 PM
DBL001's Avatar
DBL001
just use a good quality anti-freeze and follow the directions for solvency, I would drain some anti-freeze then disconnect the upper radiator hose and continue draining thru the plug, might consider a flush too. Good time to change hoses and thermostat, cheap insurance
Old Apr 15, 2007 | 02:22 PM
csexton's Avatar
csexton
This should help you
Chuck
The procedure follows:
Draining and Filling Cooling System
Caution
With a pressurized cooling system, the coolant temperature in the radiator can be considerably higher than the boiling point of the solution at atmospheric pressure. Removal of the surge tank cap, while the cooling system is hot and under high pressure, causes the solution to boil instantaneously with explosive force. This will cause the solution to spew out over the engine, the fenders, and the person removing the cap. Serious bodily injury may result.
Important
If the procedure below is not followed a low or high coolant level condition and/or vehicle damage could result.
1) Park the vehicle on a level surface.
2) Remove the surge tank cap:
3)Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
4) Place a drain pan under the drain plug.
5) Open the radiator drain plug .
6) Allow the cooling system to drain completely.
7) Inspect the engine coolant for the following:
Discolored -- follow the flush procedure below.
Normal in appearance -- continue with the next step.
Notice
When adding coolant, use DEX-COOL® coolant. If silicated coolant is added to the system, premature engine, heater core or radiator corrosion may result. In addition, the engine coolant will require change sooner-at 50 000 km (30,000 mi) or 24 months.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
8) Close the radiator drain plug. Tighten.
Tighten the radiator drain plug to 2 N•m (18 lb in).
9) Fill the cooling system through the surge tank.
10) Fill the cooling system with a 50/50 mixture of DEX-COOL® coolant and deionized water.
11) Start the engine.
12) Allow the engine to idle for 1 minute.
13) Install surge tank cap.
14) Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F).
15)Shut off the engine.
16) Remove the surge tank cap.
17) Start the engine.
18) Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank.
19) Install the surge tank cap.
20) Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F).
21) Shut off the engine.
22) Remove the surge tank cap.
23) Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank.
24) Rinse away any excess coolant from the engine and the engine compartment.
25) Inspect the concentration of the engine coolant.
26) Install the surge tank cap.
Old Apr 15, 2007 | 02:30 PM
kevo187's Avatar
kevo187
does the radiator drain plug simply screw off?:o
Old Apr 15, 2007 | 03:12 PM
hermit's Avatar
hermit
It's not really a plug as you would expect , more like a valve. Just loosen it to let the coolant flow. It only turns about 1/2 - 3/4 turn to do the job.
To Radiator flush
