How difficult to swap the differential pumpkin?
Old Apr 15, 2007 | 07:02 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Default How difficult to swap the differential pumpkin?
Does anyone have a write up or link for a how to?
How long of a job is this?
Any special tools needed?
TIA
Old Apr 15, 2007 | 07:27 PM
94legaleagle's Avatar
94legaleagle
CajunDude has a great write up, and he also has a link to Mike Mercury who has a write up - follow these 2 write ups and it's EZ!!
Old Apr 15, 2007 | 07:49 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
I can do it in an hour with a lift. Its really pretty easy..
Old Apr 15, 2007 | 07:52 PM
Geneus's Avatar
Geneus
You know, someone will have a smartazz response to this...but it isn't going to be me.
Old Apr 15, 2007 | 07:57 PM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Originally Posted by PeteZ06
Does anyone have a write up or link for a how to? How long of a job is this? Any special tools needed? TIA
Give this a try, it's very good..
http://www.cajundude.com/differential.htm
Old Apr 15, 2007 | 08:21 PM
vettenuts's Avatar
vettenuts
So far I have helped with one and will be doing mine shortly. It really isn't bad as long as you have the right jacks, etc.
Old Apr 15, 2007 | 08:22 PM
Wisdom's Avatar
Wisdom
An hour, huh? It takes me that long to read and digest Cajun's very detailed writeup!
Old Apr 15, 2007 | 09:37 PM
philsy's Avatar
philsy
Four hours on the floor with jack stands , just did mine yesterday with one of my buddies . the only problem we had was not having the input seal for the rear but we came up one after a little searching... be sure you have one to install it before switching it up ... it was the only road bump we hit.... good luck
Old Apr 16, 2007 | 11:20 AM
Cruise-In V Veteran
Lets just say that we have a pretty decent handle on the C5 platform..
Old Apr 16, 2007 | 11:54 AM
Scotty3's Avatar
Scotty3
I followed CajunDude & Mike Mercury’s write-ups and it made everything go smoothly. I went from a 2:73 to a 3:43 with the stock stall for now, I can always change it later. Got Jeff Creech (Carolina Auto Masters) to do the tune. What a difference that gear makes. It took me about 8 hours total, working by myself, with the car on jack stands. I didn’t have a transmission jack so I used my motorcycle jack. It worked fine.
Old Apr 16, 2007 | 11:55 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Oh yea, well I can do it in an hour on jackstands now.
To How difficult to swap the differential pumpkin?
