Rear Brakes
Old Apr 16, 2007 | 07:14 PM
RedC5's Avatar
RedC5
Default Rear Brakes
Is the rear brake pad installation is the same as the front but both bolts need to be removed per side since caliper does not have room to swing as the front does? Any other difference or tips to know when replacing?
I did the fronts pretty easy last year....
Old Apr 16, 2007 | 08:05 PM
SLPRC5's Avatar
SLPRC5
You are correct..do a search here on the forum on how to change the brake pads there is a nice step by step write up.
Old Apr 16, 2007 | 09:15 PM
UstaB-GS549's Avatar
UstaB-GS549
I think if you take the bottom bolt out and hinge caliper out of the way you can just pull the pads out... or maybe its the top... if you do the wrtong one you have to pull hose around rear brake duct... assuming you have Z06.
To Rear Brakes
