Sorry... another diff question
Old Apr 17, 2007 | 07:13 PM
N0TDADYS_98's Avatar
N0TDADYS_98
Default Sorry... another diff question
ok... i've asked a handful of diff questions this last week and still have another...
I just need clarification now, because some of the answer i get are not 100%
http://www.c5frc.com/DIY/Hardened_Ou...haft/index.htm
This is step by step on how to replace the output shaft... and i found another one for replacing the right one as well... it seems pretty easy... easier than replacing a cam....
I mentioned in a thread that i was interested in upgrading my gears to 4.10s. but i was advised this was a bad idea as it requires a bunch of special tools.. not to sound like a smart a$$.. but looking at this install the gears are right there... i would really like some clarification on what i need professional help with and what i can do myself....
So to make this easy and make sure i get my answers...
Which items are a DIY and which require a professional???
Left (output shaft)
Right (output shaft)
clutch packs?
Gears?
also what gaskets/seals need to be replaced after a DIY job?
Old Apr 17, 2007 | 07:17 PM
FRCTony's Avatar
FRCTony
Gears require tools and experience to set up correctly, period.
It will only cost you about $400 bucks to find out if you can wing it...
Old Apr 17, 2007 | 09:18 PM
N0TDADYS_98
So the clutch/and shafts can be done by a diyer?
Old Apr 17, 2007 | 10:03 PM
tiojames's Avatar
tiojames
I think the set of tools specific for this work run about $1100. I have set up many Ford and chevy rears and I would not try my verts diff. I had Andy at A&A change out the gears.
To Sorry... another diff question
