C6 HUD in a C5
Old Apr 18, 2007 | 11:19 AM
02MillenniumVette's Avatar
02MillenniumVette
Default C6 HUD in a C5
Did a search and cant find anything. Has anyone tried or know if it will even work to put the C6 HUD in a C5? Thanks in advance.
Old Apr 18, 2007 | 11:36 AM
beav626's Avatar
beav626
Old Apr 18, 2007 | 11:52 AM
pimpjames's Avatar
pimpjames
Whats the difference in them? I am curious now
Old Apr 18, 2007 | 12:03 PM
02MillenniumVette
Here are some of the things that the C6 HUD does.
There are two settings for the HUD: Street and Track; and each setting is preprogrammed to display information that is relevant for each respective – and very different – situation. In Street mode, the driver can select between several configurations that feature the speedometer and the turn signal indicators, and then add to it other information such as audio system data, automatic transmission gear position, and high-beam indicator. In Track mode, there is a larger tachometer, a speedometer, engine condition gauges, and a real-time lateral accelerometer that samples and displays the maximum “g-force” experienced during a turn.
Old Apr 18, 2007 | 12:27 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
I doubt its easily possible. Things like the g-meter wouldn't function unless you also added an accelerometer somewhere in the car, which most likely has to interface with the computer, so you'd have to do a computer upgrade, etc, etc.
Old Apr 18, 2007 | 01:20 PM
SilvaDragon's Avatar
SilvaDragon
The HUD unit is just a projector. All the data it projects comes from
the cluster, and the cluster gets it from the computers.
So, this is not a trivial upgrade.
Old Apr 18, 2007 | 04:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Most likely just aint going to happen. Well at least not easily!
Old Apr 18, 2007 | 04:54 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I'm with Bill, I've gotten requests from C6 owners to add the HUD(hasn't been tryed yet), I'm not going to front the $$ for the R&D for a project that only applies to 5% of the C6 market(potential non HUD cars)
Old Apr 18, 2007 | 11:41 PM
nj02vette's Avatar
nj02vette
Adding a HUD to a C6 may be a pain, but I think adding the C6 HUD to a C5 would be near impossible.
Old Apr 19, 2007 | 02:07 AM
Bill Dearborn's Avatar
Bill Dearborn
The C5s have the accelerometer as part of the Active Handling. The problem is programming the computer to recoginize the C6 HUD and to pull the on board data and send it to the HUD. Without some knowledge of the software and probably a probably a redesign of the hardware/software interface to the C6 HUD it would be very difficult to do this. Given the right information a computer junky probably could make it work.
Bill
To C6 HUD in a C5
