Flushing A/C System Question?????
Old Apr 18, 2007 | 02:21 PM
gonbad's Avatar
gonbad
Default Flushing A/C System Question?????
OK I have a dead compressor. I have purchased a new compressor, accumulator, and orifice tube. The system has been dry for over a year and I intend to have it flushed. The question is should it be flushed before I install the new parts or after?
Old Apr 18, 2007 | 02:38 PM
VetteDrmr's Avatar
VetteDrmr
Before. No reason to put flush into pristine parts.
HTH, and have a good one,
Mike
Old Apr 18, 2007 | 03:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BEFORE!! Flush out all the bad, install all the new. Make SURE that you add the required oil for each part you replace, The compressor normaly comes with oil. Once you flush, you remove the oil from the evap, condensor lines and dryer. Make sure that you add it back.
BC
To Flushing A/C System Question?????
