LS2 computer pin assignments
Pin
Wire Color
Circuit No.
Function
1-3
Not Used
4
PU/WH
1035
Starter Relay Coil Supply Voltage
5
Not Used
6
GY/BK
48
CPP Switch Signal
7-8
Not Used
9
WH
17
Stop Lamp Switch Signal
10
PU/WH
1668
HO2S High Signal Bank 1 Sensor 2
11
TN/WH
1669
HO2S Low Signal Bank 1 Sensor 2
12
OG/BK
380
A/C Refrigerant Pressure Sensor Signal
13
BK/WH
2751
Low Reference
14-15
Not Used
16
D-BU
1936
Fuel Level Sensor Signal - Secondary
17
Not Used
18
YE
43
Accessory Voltage
19
PK
1439
Ignition 1 Voltage
20
RD/WH
2440
Battery Positive Voltage
21-22
Not Used
23
PU
1272
Low Reference
24
D-GN
890
Fuel Tank Pressure Sensor Signal
25-26
Not Used
27
TN
2501
ECM High Speed GMLAN Serial Data Bus -
28
TN/BK
2500
ECM High Speed GMLAN Serial Data Bus +
29
D-BU
1161
APP Sensor 1 Signal
30
BN
1271
Low Reference
31
TN
2759
Low Reference
32
L-BU
1162
APP Sensor 2 Signal
33
GY
2709
5-Volt Reference 1
34
GY
2700
5-Volt Reference 1
35
Not Used
36
TN
1274
5-Volt Reference 1
37
TN
472
IAT Sensor Signal
38
TN
2760
Low Reference
39-40
Not Used
41
YE
492
MAF Sensor Signal
42-46
Not Used
47
PK
439
Ignition 1 Voltage
48
WH
121
Engine Speed Signal
49
TN
1671
HO2S Low Signal Bank 2 Sensor 2
50
D-GN/WH
465
Fuel Pump Relay Control
51-55
Not Used
56
WH/BK
1164
5-Volt Reference 2
57
D-GN/WH
817
Vehicle Speed Signal
58
D-GN
335
Cooling Fan Relay Control
59
WH/BK
448
Ignition 1 Relay Control
60
Not Used
61
WH
1310
EVAP Canister Vent Solenoid Control
62
Not Used
63
D-GN/WH
459
A/C Compressor Clutch Relay Control
64
OG/WH
3223
HO2S Heater Low Control Bank 2 Sensor 2
65
BN
2391
HO2S Heater Low Control Bank 1 Sensor 2
66
GY
587
Skip Shift Solenoid Control
67
YE/BK
625
Starter Enable Relay Control
68
BN/WH
419
MIL Control
69
PU
1670
HO2S High Signal Bank 2 Sensor 2
70
L-BU
1937
Fuel Level Sensor Signal - Right
71
YE
400
VSS High Signal
72
PU
401
VSS Low Signal
73
BK/WH
451
Ground
Engine Control Module (ECM) C2 (MM6/MZ6)
Pin
Wire Color
Circuit No.
Function
1
Not Used
2
L-GN
1867
5-Volt Reference 2
3
L-BU/BK
1688
5-Volt Reference 2
4
Not Used
5
BN
582
TAC Motor Control 2
6
YE
581
TAC Motor Control 1
7
Not Used
8
D-GN/WH
428
EVAP Canister Purge Valve Control
9-10
Not Used
11
L-GN
1652
Reverse Lockout Solenoid Control
12
GY/WH
3113
HO2S Heater Low Control Bank 1 Sensor 1
13
L-GN
3212
HO2S Heater Low Control Bank 2 Sensor 1
14-16
Not Used
17
D-BU/WH
878
Fuel Injector 8 Control
18
TN/WH
845
Fuel Injector 5 Control
19
YE/BK
846
Fuel Injector 6 Control
20
TN
1744
Fuel Injector 1 Control
21
YE
410
ECT Sensor Signal
22
TN
2761
Low Reference
23
TN/WH
585
Transmission Fluid Temperature Sensor Signal
24
OG/BK
586
Low Reference
25
Not Used
26
D-BU
496
KS 1 Signal
27
GY
1716
KS 1 Signal
28
Not Used
29
L-BU
1876
KS 2 Signal
30
GY
2303
KS 2 Signal
31
Not Used
32
GY
23
Generator Field Duty Cycle Signal
33
BN
1174
Oil Level Switch Signal
34
BK
2755
Low Reference
35
TN/WH
1704
Low Reference
36
Not Used
37
L-GN/BK
1745
Fuel Injector 2 Control
38
PK/BK
1746
Fuel Injector 3 Control
39
L-BU/BK
844
Fuel Injector 4 Control
40
OG/BK
877
Fuel Injector 7 Control
41
GY
2705
5-Volt Reference 1
42
Not Used
43
GY
2704
5-Volt Reference 1
44
OG
631
5-Volt Reference 1
45-49
Not Used
50
TN/WH
331
Oil Pressure Sensor Signal
51-52
Not Used
53
OG/BK
469
Low Reference
54-55
Not Used
56
TN
1664
HO2S Low Signal Bank 1 Sensor 1
57
PU/WH
1665
HO2S High Signal Bank 1 Sensor 1
58
L-GN
432
MAP Sensor Signal
59
PU
1666
HO2S High Signal Bank 2 Sensor 1
60
TN
1667
HO2S Low Signal Bank 2 Sensor 1
61
OG
225
Generator Turn On Signal
62
Not Used
63
PU
486
TP Sensor 2 Signal
64
BN/WH
633
CMP Sensor Signal
65
D-GN
485
TP Sensor 1 Signal
66
PK/BK
632
Low Reference
67
Not Used
68
D-BU/WH
1869
CKP Sensor Signal
69
YE/BK
1868
Low Reference
70
PU
2121
IC 1 Control
71
PU/WH
2128
IC 8 Control
72
OG
2127
IC 7 Control
73
OG/WH
2122
IC 2 Control
74
L-BU/WH
2126
IC 6 Control
75
D-GN
2125
IC 5 Control
76
D-GN/WH
2124
IC 4 Control
77
L-BU
2123
IC 3 Control
78
BN
2129
Low Reference
79
BN/WH
2130
Low Reference
80
Not Used
