I looking for a spot to get some small wires from the engine compartment to inside the car without taking apart a bunch of stuff. Have searched but found nothing. Have looked from the top and don't see a place. The hood latch wires are a possibility from the inside.
Does anyone know of a fairly easy place to get wires through the firewall so i can put them on either side under the dash? Or a place you can drill easily with no trouble. TIA
follow the hood cables, I run wires for meth/gages/boost in that area, remove 9 7mm screws for the aft fender panel and you in there, drill and grommet/seal the hole
