changing fan temperatures
Old Apr 18, 2007 | 10:18 PM
gregcook's Avatar
gregcook
Default changing fan temperatures
Hi all
Is there a way to change at what temperature the fans come on without sending the pcm in for a tune.I just want the car to run a little cooler here in Florida .Plan on a 160 t stat also
Best regards Greg
Old Apr 18, 2007 | 10:52 PM
SLPRC5's Avatar
SLPRC5
Originally Posted by gregcook
Hi all
Best regards Greg
Put in the 160 stat first, take it to a tunner and have the fans reset..cost about $75.00 to do it.
Old Apr 18, 2007 | 11:26 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Try this: http://www.zip-products.com/Corvette...D8E0C85D17D26A
or any hand held programmer like a Hypertech:
Old Apr 19, 2007 | 12:28 AM
brandtdavis's Avatar
brandtdavis
doesn't ecklers sell a fan controller. Mines in the bathroom or I would look it up for you. I think its pricey though.
Old Apr 19, 2007 | 12:51 AM
NOS500's Avatar
NOS500
I believe thats like 175 bucks.
You should probably put in a 160 thermostat then go to a tuner and have them reprogram the fans to come on earlier.
Old Apr 19, 2007 | 01:53 AM
SLPRC5's Avatar
SLPRC5
Same said in post #2
Old Apr 19, 2007 | 09:16 AM
vettenuts's Avatar
vettenuts
I use the Vinci fan controller and it works very well. You can set the on temp, the fans shut off 7 degrees under that. Mine is set on at 208 and off at 201 running the stock thermostat.
Old Apr 19, 2007 | 04:51 PM
FKING1's Avatar
FKING1
Same here
Old Apr 19, 2007 | 08:40 PM
Got DV/DT's Avatar
Got DV/DT
Where in Florida are you? I am in Palm Harbor (near Tampa) and have HP Tuners. For $100 we can add you too my licence and I can change that, and a few other things for you if you want. Things like:
O2 delete
Shift points
Fuel cut offs
CAGS eliminate
COT eliminate
Shift light setup
I am not trying to make any money, just trying to help. Let me know.
Old Apr 20, 2007 | 12:06 AM
David Borden's Avatar
David Borden
Where can I get a 160 thermostat? Is this a good mod? I have a LS6 thats in a mid engine car and the underhood temps might get a bit hot.
David
Old Apr 21, 2007 | 02:34 PM
Got DV/DT's Avatar
Got DV/DT
Summit, Jegs, and about 100 other online performance sites.
As for being a good mod, that is open for debate. I run the 160* but I live in Florida and I drag race. For that combo, it works well. Up north or for a daily drive, you might want to go a little warmer, maybe a 180* or stay with stock (195*).
If you change the thermostate, you will need tuning to adjust your fan settings.
Old Apr 21, 2007 | 08:50 PM
valkrod's Avatar
valkrod
would you help someone from Jax Fl if in your area for a weekend?
Ken in Jax
Old Apr 21, 2007 | 09:32 PM
warren s's Avatar
warren s
For about 8 bucks for switch and wire you can put in a manual fan control switch.
Old Apr 22, 2007 | 02:14 AM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
For no bucks, if you want the fans to come on, just push the A/C button. Then both fans will come on at high speed and cool the radiator down as well as you getting cooled down from the A/C unit.
Old Apr 22, 2007 | 08:37 AM
gregcook's Avatar
gregcook
Hi
If you are requesting help from me(i live in Jax)I would be more than happy to provide it Cell 904 318 0848
Regards Greg Cook
To changing fan temperatures
