Must Pass Inspection
Old Apr 19, 2007 | 12:41 PM
QUICKSLVR's Avatar
QUICKSLVR
Default Must Pass Inspection
CHECK ENGINE LIGHT STAYS ON WITHOUT CATS. GOTTA GET A STATE
INSPECTION. HARD BREATHIN CAM KEEPS LIGHT ON. WHO KNOWS A PLACE LOCAL THAT WILL PASS IT. OR A QUICK FIX. ??
Old Apr 19, 2007 | 01:35 PM
gonbad's Avatar
gonbad
Who tuned it? They should have set the tested parameters to always show OK during the test. If you have a CEL then it will not pass. I don't know of any shops that will just give it a sticker. You need to contact your tuner or if you tuned it yourself you need to learn which parameters to set to OK.
For a quick fix you can call HPE and see if they will tune out the OBDII codes that will cause it to fail.
Old Apr 19, 2007 | 02:46 PM
QuikZilver's Avatar
QuikZilver
Did you add 02 sims when you took off your cats?
Old Apr 19, 2007 | 05:10 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
Should have had codes deleted,when tuned.Have you cleared codes,in DIC??How long since cam install?Tom,give me a shout,we'll see what we can do.jerry
Old Apr 19, 2007 | 05:20 PM
XKR100's Avatar
XKR100
Tom,made a call.Come by tonight and shoot the breeze,may have a hookup.jerry
Old Apr 20, 2007 | 11:32 AM
QUICKSLVR's Avatar
QUICKSLVR
Default Thanks
THANKS FOR THE REPLYS.......GOOD TO GO.
Old Apr 20, 2007 | 01:12 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Curious what solved the problem.
To Must Pass Inspection
