Bought a used C5, need some advice
Old Apr 20, 2007 | 03:52 AM
Shakor's Avatar
Shakor
Default Bought a used C5, need some advice
Hello, Im new to the forum and also a new Corvette owner. Its truly a fabulous and beautifil car.
However I just bought a -99 C5 model and I have some problems. The car has a manual transmission.
First the display gives me a warning about low oil level but the gauge shows 250-350 kpa which I believe is within the accepted parameters. So what is wrong here, the gauge or the display?
Also I have noticed that when I run 15-20 km/h (9-12 MPH) and ONLY during this interval I hear a low rassling noise from the back of the car.
Anyone got a clue what these errors could be about and if it is serious enough for me not to use it until a certified mechanic examines the car?
I did perform a standard test on the car by mechanic before I bought it and he did not note any serious issues.
Old Apr 20, 2007 | 07:33 AM
beav626's Avatar
beav626
Welcome to the Forum
1. This is a common problem with the oil level indicator. Check your dip stick to be sure...
2. This could be a loose exhaust bolt back there. Go back there and try to look for anything that could rattle and tighten it.
Good luck and I hope you enjoy your new car, It is awesome
CARRJET's Avatar
CARRJET
Do you have a owners manual? if not, do a search on this forum and you will find an electronic copy avaiable. welcome to the Corvette family
Old Apr 20, 2007 | 08:11 AM
bluvette79's Avatar
bluvette79
my 99 does this every once in a while after it is parked on an incline. just check the dip stick and reset the message. i agree with the muffler/exhaust rattling either due to lose or someone backed over a parking block and shoved one of the mufflers out of position and it is rubbing. thats what happened to mine.
welcome aboard!
Old Apr 20, 2007 | 08:14 AM
Blueleader's Avatar
Blueleader
Until I had the oil changed at the Mobil oil shoppe, I got the same indications. Best thing to do is to have a top vette mechanic check it out bumper to bumper. You now have the key to happiness, start gleaning thru the forum for all kinds of great info from a bunch of fun people who take ownership very seriously. Put the fun in dysfuntional sometimes too. Welcome!!!
Old Apr 20, 2007 | 08:19 AM
happa's Avatar
happa
Welcome! I agree with all the other guys, check it and hope you find your problems
Old Apr 20, 2007 | 08:23 AM
Oldvetter's Avatar
Oldvetter
Oil level has nothing to do with oil pressure (until your oil gets lower than the pickup tube, then you have serious problems). When your low oil level comes on, check your oil level using the dip stick.
Your noise could be tire noise, have an experienced C5er check your car. I would also check level of differential fluid, leaking differentials is a common problem. Be sure to check the differential and not the transmission (they are next to each other).
Old Apr 20, 2007 | 10:34 AM
robvuk's Avatar
robvuk
THANK YOU!. I was wondering why no one had mentioned this so far!
Old Apr 20, 2007 | 11:58 AM
Shakor's Avatar
Shakor
Thanks guys you've been very helpful.
I drove about 20 miles with the low oil level indicator. Is there a chance I've damaged the engine?
Old Apr 20, 2007 | 12:01 PM
beav626's Avatar
beav626
check the dip stick... If it is normal no worries... If it is low add Mobile 1
Old Apr 20, 2007 | 12:19 PM
Shakor's Avatar
Shakor
Ok, will do that. Thanks again.
Old Apr 20, 2007 | 02:49 PM
maestro300's Avatar
maestro300
You may need a new low oil sending unit. Its located below the starter to the side of the oil pan. If you need pics let me know.
The rattling noise you're hearing 15-20 km/h is probably normal... but without hearing it I'm not sure. There are several threads about the rattling noise from the rear (I get it too and never goes away until above 10mph or so) I'm pretty sure thats what it is... it affects all M6 C5's
Old Apr 21, 2007 | 09:30 AM
sjc*2's Avatar
sjc*2
Default Rattling exhaust
If its a stock exhaust you might have a baffle broken inside the muffler. Happened to my 02, Give each one a hit with your fist or rubber hammer. That will tell you if its loose inside. If so, what a great excuse for new aftermarket system.
To Bought a used C5, need some advice
