LS1 intake vs LS6 Intake
Old Apr 12, 2007 | 10:11 PM
thels1kid's Avatar
thels1kid
Default LS1 intake vs LS6 Intake
I have a 98 LS1. Pretty peaked without major work about 396hp at the wheels, I want to change My intake manifold for a LS6. Will that do much for me and is there a down fall? Or will it work at all.
Old Apr 12, 2007 | 10:19 PM
cruisemon's Avatar
cruisemon
Dude - 396 ponies says you probably have added a cam and/or maybe done a little head work, maybe long tube headers. If that is the case, the LS6 PLUS a good tune should help put the number on the other side of 400.
Charlie
Old Apr 12, 2007 | 10:25 PM
SLPRC5's Avatar
SLPRC5
Charlie
or a very rare '98. Which brand dyno was used?
Yes the LS6 intake is a very good mod..go for it
Old Apr 12, 2007 | 10:31 PM
Tigershark3's Avatar
Tigershark3
"396 RWHP without major work" Doubt it. It would help if you filled out your profile.
Lynch Z06's Avatar
Lynch Z06
I've got one for sale....if you want one.
Old Apr 12, 2007 | 10:39 PM
2000whitec5's Avatar
2000whitec5
From: 10.54 @ 129 346 N/A A4 Record 9.78 @ 139+ on 150 shot
I went from the ls1 to the fast 90/90 set up picked up 25rwhp and 20tq
when my car was cam only... my friend with a simalar set up went with ls6 and picked up 12/10
Old Apr 12, 2007 | 11:24 PM
STLKillerC5's Avatar
STLKillerC5
LS6 intake should get you an extra 12-15 RWHP. The question is..is that small gain really worth the $500 for the intake and more $$$ for a tune?? I would save my money if I were you.
Old Apr 12, 2007 | 11:30 PM
vetterlatethannever's Avatar
vetterlatethannever
On my car which has cam, L/T headers, intake and U/D pulley the LS6 netted me 4.54 RWHP. Same day, same dyno. MTI forgot to install it with my other mods so they installed and dyno'd it immediately after. Didn't pick up the 12-15 they said it would.......
Should get you to 400 though.
Old Apr 12, 2007 | 11:53 PM
IFLUBYU's Avatar
IFLUBYU
Maybe a few over, worth it in my view, very easily done.
You will need a coolant tube bypass kit, the LS6 intake does not have space underneath for the coolant tube.
Old Apr 12, 2007 | 11:54 PM
nitrojunky's Avatar
nitrojunky
Mine was right at $300.
Old Apr 12, 2007 | 11:55 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Charlie
YUP! Over 400HP would be what the doctor ordered along with the prescribed LS6 manifold.
I also just seen one for sale in the for sale section!
Check these out!
http://www.tpis.com/plog/index.php?o...Id=14&blogId=1
http://www.ls1howto.com/index.php?article=5
These give you some before and after numbers to look at too!
Thanks,Matt
Old Apr 12, 2007 | 11:56 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
He could also just grind the fins down on the bottom of the intake. I did it that way with no problem
Old Apr 13, 2007 | 07:46 AM
99 vett babycar's Avatar
99 vett babycar
Old Apr 13, 2007 | 10:09 AM
madmatt9471
Don't do that unless you are very skilled! If you do you can very very easily take off too much material and put a hole in the bottom of the manifold
IT IS NOT RECOMMENDED TO GRIND THE BOTTOM OF THE LS6 MAIFOLD!
It is only about $60.00 for the two plugs for the rear and the bypass tube! It is simpler and safer to do! You will also save much time doing it this way!
Perhaps do a post to see everyone's who's done a LS6 manifold swap what they would do! You got my vote here for the bypass kit!
If you need the GM part numbers for the plugs and bypass tube let me know!
Thanks,Matt
Old Apr 13, 2007 | 10:15 AM
kilrb's Avatar
kilrb
You don't get to 396 with minor mods.
Old Apr 13, 2007 | 10:21 AM
cruisemon's Avatar
cruisemon
I don't know man. I heard about a guy who put one of those J.C. Whitney water vapor things and two of the fuel line magnets on '77 L48 and the horsepower went up from 148 to 152 with no other changes. And for the skeptics, that was on a for real dyno. Plus it was on that alt.auto.corvette newsgroup so you know it has to be documented and true.
Charlie
Old Apr 13, 2007 | 04:17 PM
AU N EGL's Avatar
AU N EGL
especially in a 98.
a 2002 and newer LS6 with a tune only can get 370-375+/- rwhp and with 100 octane up to 385 rwhp
This is what the SCCA T1 race vettes run.
or do you mean 296 rwhp ?? 1998 had 345 fwhp x .85 = 293 rwhp
To LS1 intake vs LS6 Intake
Old Apr 13, 2007 | 07:10 PM
Zo6Killa's Avatar
Zo6Killa
how is it that thels1kid posted this thread and has yet to respond to anyones question in all this time???
maybe he will fill us in soon on his mods
Old Apr 13, 2007 | 07:14 PM
LoneStarFRC's Avatar
LoneStarFRC
Maybe still looking for that J C Whitney dyno sheet?
Old Apr 13, 2007 | 09:39 PM
thels1kid's Avatar
thels1kid
Thanks , How much?
