Valve Springs
Valve Springs
Cruising over the Skyway Bridge at about 60mph and all of a sudden the check engine light comes on motor starts shaking and clattering. I make it slowly to a flat piece of ground and call a flatbed.
Dealer shows me "3" broken valve springs and 4 others that are distorted on my '99 daily driver with 100k and never any other problems. His comment "yah this is a real common problem on the Vettes." First I've ever heard of it. Springs were replaced with the UPGRADED style.
Aftermarket springs require more frequent replacement, stockers sound like they need replacement as well. You were lucky it didn't allow the valve to hit the piston. Does it run OK now?
The stock springs aren't that great. They cost you power too up top from not being able to control the valves as they should. This is especially true if you raise the limiter up, even a little bit.
As stated above, I would do a leak down test just to have the piece of mind.
I would also look at a set of good valve springs like manley dual springs. They may be over kill, but they do the job well. I would replace springs every 3 years or 36000 miles if I had a stock vette, but that's me.
Max
Max
