unbelivable Electrical problems
car was hit in the front and repaired. Here is my problem: driving or standing, without warning the car shuts off, fuel gage starts to go nuts left to right and back, oil pressure gauge does the same, water temt. gauge follows, all occuring at the same time. The messages that I am recieving are engine hot, low fuel ,resurve fuel,transmission temp hot, reduce power, service vehicle, service active handling,service traction control, under the engine fuel solinoid clicking and going crazy. 10-15 min later all stops, car starts no current codes. All I see is the history codes whic are: lost comunecation codes, water temp low voltage code, fuel tank low voltage code, map low voltage code , system high voltage code, trans low voltage,
all grounds cleaned, Can this be pcm problem? Please help
The car is in the process of getting a new PCM...I'll update with findings.
When the computer modules start going haywire like you describe the most likely cause is a poor ground contact that can cause noise on the BCM/PCM data lines and throw random codes and operation as you describe. Since you say you were hit and there are major ground points on the front frame rail it's very likely that the ground is intermittently opening or making poor contact. Check all the ground points, open them, clean them and make sure they are making a proper connection - I'll bet your problem will be resolved.
Ahhh ...there is only 1 PCM on this car
PCM = Power train control module
This sounds like a BCM (body control module), as stated above one of the star connectors may have a loose connection or one of the data link bus wires may be shorted.
Just to rule out 1 thing, pull up the floor mat on the passenger side and check to make sure the carpet is dry, is it?
There is no fuel solenoid under your hood, what exactly is clicking, any pictures?
The TAC module will cause the car to go into reduced power mode and will also cause a few other problems but it won't cause the cluster to freak out, thats more of a BCM problem.
