My C6ZO6 Splash Guards
Old Apr 21, 2007 | 06:35 PM
happa's Avatar
happa
Default My C6ZO6 Splash Guards
Hello everybody, I just them on and Im very satisfied. They turned out better then I thought. Tell me what you think
Old Apr 21, 2007 | 06:53 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
To be perfectly honest, I like the idea, but it looks like you used some sort of hand tool to cut the sides to fit against the car’s body. It looks a little shaky. If someone knows how to make smoother trimming on the splash guards, it would be a great addition. Maybe someone will chime in with a method of trimming and you can try it again.
JMHO,
Clayton from Las Vegas
Old Apr 21, 2007 | 07:07 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
The best method is a dremel with cutting disk and sanding disk. Cut the material off til you get close to the desired shape then use the sanding wheel to fine tune the shape. I also used a small piece of sandpaper on a block to get the edge flat. It's hard to get a really flat edge with the dremel.
It takes quite a bit of test fitting to get it matched up. But, definitaly worth it in the end. They make a very nice factory looking splash guard. Wish I could get some for the front now.
Old Apr 21, 2007 | 07:08 PM
glkfam's Avatar
glkfam
I think they are a great addition to the car cause I to hate the dirt that I get on my car right behind the rear tires. Might be the next addition to my car?
Old Apr 21, 2007 | 08:26 PM
bowtiebubba's Avatar
bowtiebubba
How did you attach them and what did you use?
Old Apr 21, 2007 | 10:12 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
i wish that some after market vendor would start to produce them
Old Apr 21, 2007 | 10:54 PM
happa's Avatar
happa
I used some plastic screws that are pretty flat on top. I wish I did have a better tool to make them better looking. I was planning on taking them off and cleaning them up.
Old Apr 21, 2007 | 11:00 PM
jdmvette's Avatar
jdmvette
Night Owl for life
they look good. just take a very fine-grit sandpaper to smooth them out.
Old Apr 22, 2007 | 02:18 AM
DeeGee's Avatar
DeeGee
Here's a How To I put together when I fitted mine
http://forums.corvetteforum.com/show...=fender+guards
Old Apr 22, 2007 | 02:20 AM
DeeGee's Avatar
DeeGee
Nice job. It's really difficult with the poor fit of the Vette fender panels to get a smooth line. You've done really well. You can still see where you sanded down and there's the odd scratch. That will bed in with use and improve after some detailing. I'd leave it a while before you pull it off. Looks great
To My C6ZO6 Splash Guards
