Code P0102
Old Apr 23, 2007 | 07:39 AM
SSquid's Avatar
SSquid
Default Code P0102
Curious... the air tube that runs into the backside drivers side of the intake... if that isnt plugged in fully.. or its loose... would that throw this code? and make it run sluggish and what not???
Old Apr 23, 2007 | 12:05 PM
vettenuts's Avatar
vettenuts
Do you mean the PCV system hose, I would think it would cause issues as the other end is plugged directly into the intake manifold right behind the throttle body on the passenger side.
Old Apr 23, 2007 | 03:43 PM
SSquid's Avatar
SSquid
Anymore input from others would be appriciated...
Old Apr 23, 2007 | 06:48 PM
vettenuts's Avatar
vettenuts
Sorry, misread your post, that sounds like the brake booster hose.
Old Apr 23, 2007 | 07:46 PM
SSquid's Avatar
SSquid
so is that a no it owuldnt cause this code?
Old Apr 23, 2007 | 07:58 PM
vettenuts's Avatar
vettenuts
A vacuum leak can cause that code, should be in the trouble shooting chart.
To Code P0102
