97 overheated fan not running
Old Apr 23, 2007 | 12:29 PM
4aces's Avatar
4aces
Default 97 overheated fan not running
My 97 overheated to 265 degrees when I pulled over and the fans were not running I checked the fuse and it was ok. Any ideas? thanks Dave
Old Apr 23, 2007 | 12:40 PM
willyfastz's Avatar
willyfastz
Check the relays, there's three of them, also if the temp sensor is going bad the fans wont work.
Old Apr 23, 2007 | 01:04 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Isnt the sensor thats connected to the lower radiator shroud associated with the fans? Not sure though...
If so, that would be a fairly simple check..
Old Apr 23, 2007 | 04:02 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
The sensor on the lower radiator shroud is for outside air temp... the coolant temp sensor is at the front of the driver's side head.
Old Apr 23, 2007 | 05:27 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Turn on A/C as this over-rides and turns on the fans.
If you get no response, you definitely have some kind of electrical problem.
Old Apr 27, 2007 | 11:28 PM
4aces's Avatar
4aces
They turn on when the A/c is on. Where are the sensors and relays? Which should I start with? Thanks Dave
To 97 overheated fan not running
