Tire Pressure
Old Apr 24, 2007 | 10:54 AM
Gene Moses's Avatar
Gene Moses
Default Tire Pressure
Can you folks give me some normal tire pressure reccommendations for the folloing Good Year tires on a street driven 2002 C5 Convertible:
Rear P275 40ZR18
Front P245 45ZR17
Old Apr 24, 2007 | 11:23 AM
JasB's Avatar
JasB
I believe it should be 30psi cold all around. That what it should say on your door. At least that is what it says on my Y2K C5.
Jim
Old Apr 24, 2007 | 01:01 PM
jovette's Avatar
jovette
Yep, owner's manual says 30 lbs. cold. I am running less air pressure, since I am seeing more wear on the middle of the tire on my OEM run flats, especially the rears. I'm running 28 cold front and 26 cold rear. Once they warm up, it's like 32 and 30 respectively.
Old Apr 24, 2007 | 01:32 PM
VetteDrmr's Avatar
VetteDrmr
Non-runflats, 28f, 26r, cold.
Have a good one,
Mike
Old Apr 24, 2007 | 09:23 PM
cruisemon's Avatar
cruisemon
26 psi lights up the tire pressure sensor warning on my '98. Any thoughts about this, like maybe a faulty tps or ???
Charlie
Old Apr 24, 2007 | 10:50 PM
VetteDrmr's Avatar
VetteDrmr
Hmm, my TPWS shouts out when the pressure gets down to 25, not 26. If your's yells at 26, then I'd set them at 27.
Have a good one,
Mike
Old Apr 24, 2007 | 11:47 PM
rws.1's Avatar
rws.1
For even wear across the treads I use 28 cold all around which usually gets me to 32 hot
Old Apr 25, 2007 | 07:48 AM
Joy of 6's Avatar
Joy of 6
Guess I am a high preassure guy. find that 32 rear and 36 front works real well for tractin and wear consistency across the tread. I am an aggressive driver. (not the same as road rage)
Old Apr 25, 2007 | 10:48 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
30 cold
Old Apr 25, 2007 | 05:13 PM
RogerT's Avatar
RogerT
Long time Goodyear tire dealer/ personal friend told me to put 35 pounds, front and rear, for maximum tire tread life.
Roger T
Old Apr 25, 2007 | 05:24 PM
JWB ZO6's Avatar
JWB ZO6
28 cold warms up to 32 for me
Old Apr 25, 2007 | 05:58 PM
screw991le's Avatar
screw991le
30 cold will turn into 32-35psi when running at temp. To much air and you'll wear the tire sooner. The sticker on the door will tell you what you should be running for psi in any tire.
Old Apr 25, 2007 | 07:25 PM
lucky131969's Avatar
lucky131969
Rear P275 40ZR18
Front P245 45ZR17
What I find quite mind boggling is the myriad of responses you will get regarding this question. Provided you are talking straight street/daily driving, default to the recommended tire pressure on the drivers door. Why reinvent the wheel, when someone has already done the homework for you? Some stuff just doesn't make sense like: better traction with overinflated tires. Just think about it. Follow the factory specs, you won't be sorry.
Old Apr 26, 2007 | 02:28 AM
2blklt4's Avatar
2blklt4
30 psi cold........period
Old Apr 26, 2007 | 08:13 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Yeppir, me too
Old Apr 26, 2007 | 04:27 PM
lucky131969
Originally Posted by mrm1149
Yeppir, me too
And what exactly is hot? Since the tire pressure raises 1 psi for every 10 degrees temperature.
Old Apr 27, 2007 | 03:13 AM
RIJVETTES's Avatar
RIJVETTES
Roger T
Yup. I have consistently used about 36-37 lbs cold- both in my 93 C4 and 02 C5, daily street driven. Better wear and performance. Ya gotta get up on your toes to run. Stop draggin around the rubber n buying tires every 15K miles. Before some of you yell that it exceeds GM's recommendations, give it a try. Your vette will feel firmer and quicker. Its not a Buick.
To Tire Pressure
Old Apr 27, 2007 | 08:06 AM
cruisemon's Avatar
cruisemon
I run 32 psi and the difference between 32 and 27 psi is noticeable. The "feel" through the steering wheel is subjectively better, and fuel economy is about .5 mpg better, maybe a little higher.
Charlie
Old Apr 27, 2007 | 12:48 PM
lucky131969
Truly scary.
Old Apr 27, 2007 | 09:16 PM
Sorny's Avatar
Sorny
Better performance?
There is a reason the manual recommends 30PSI.
