Tire Pressure
34-35psi. i use non runflats. different road temps and outside air temps affect tires "hot" psi. the door sticker is at 30psi from the factory. that is a good "safe" number for the masses to use considering the differences the cars could see from one areas climate to another. if your tires are seeing 37,38,39, or 40 psi hot. i think it should be adjusted down in pressure some cold to keep from getting bald spots in the middle too early.
