A4 Shift Knob
Old Apr 24, 2007 | 07:47 PM
brian vette's Avatar
brian vette
Default A4 Shift ****
Anyone know how to remove shift **** from A4 without destroying it?
Old Apr 24, 2007 | 08:04 PM
glackore's Avatar
glackore
There is usually a clip on the front side of the shiftknob about midway up. It is in the front so it is hidden. Just slip a small screwdriver between the clip and the shiftknob and pry it out a bit. Then, you can pull it out with a needle nose plier.
The cap pulls off and the inner plastic piece detaches from the shifter by turning it ( I think I remember correctly).
The **** should slip right off after that!
G-Man
Old Apr 24, 2007 | 08:15 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
turn the key to the on position without actually turning the car on. put the e-brake on. put the shifter into first gear. there is a small staple on the back side of the shift ****. you need to get a very small flat head screwdriver to pry the staple out. then the shift **** comes right off!
Old Apr 25, 2007 | 09:52 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Sometimes you need to pull up hard, just watch your face
To A4 Shift Knob
