Harmonic Balancer Removal
Old Apr 25, 2007 | 08:04 AM
RedHotZO6's Avatar
RedHotZO6
Default Harmonic Balancer Removal
What is the best procedure for removing the Balancer on these C5's. I am doing a cam swap and have removed the radiator but the steering rack is in the way. Can the rack be unbolted, picked up and moved out of the way or does it need to be removed all together? My C5 is a 1999 and has the Antilock Brake Controller, does this need to be removed? Any help would be appreciated. Thanks,
Paul
Old Apr 25, 2007 | 09:01 AM
94legaleagle's Avatar
94legaleagle
here is the cam swap write up you need to follow:
http://www.ls1howto.com/index.php?article=1
You HAVE to remove the steering rack to get the crank pulley off - print off the above LS1 article, and follow it almost religously.
Old Apr 25, 2007 | 08:46 PM
double-oh-coupe's Avatar
double-oh-coupe
Old Feb 2, 2008 | 09:28 AM
ZEX-Z's Avatar
ZEX-Z
Nicely done.
Old Feb 2, 2008 | 10:37 AM
LDB C5's Avatar
LDB C5
If you follow those directions "religously" you are asking for TROUBLE.
DO NOT use the Crank bolt to remove the balancer!!! You will end up pulling on the last (first) couple of threads in the crank! Pull tose threads out and or break that bolt off in teh crank and you will regret it.
Same goes for the reinstallation. Make a reinstall tool.
I really wish they would fix those instructions
Old Feb 2, 2008 | 10:41 AM
vettenuts's Avatar
vettenuts
I can't agree more. It is a good guide, but there are several pitfalls on that web site that can lead to a real mess. The biggest thing you will run into immediately is the pulley removal. Don't use the old bolt to push on with the puller, use a socket or solid piece and push against the end of the crank snout.
Old Feb 2, 2008 | 10:55 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
get the tool you see in the GM manual, it's on xbay for about 60 bucks, made by OTC
about a 3 minute job
all other tools are absolute bulls%%t
Install, 618hawk over on lstech
don't skimp on the tools, pay attention to tech data(GM manual)
Old Feb 2, 2008 | 10:58 AM
LDB C5's Avatar
LDB C5
I use a LARGE socket that will contact the snout of the crank; and slip a bolt ( ~ 3/8") through the 1/2" drive hole. The head of the bolt contacts the socket, and if you use a "soft" bolt, the point on the puller screw will form it's own seat!
Note to Vettenuts: Thanks for all of you help with my valve cover / pcv issues! I appreciate it Car is done & tuned... see below
Old Feb 2, 2008 | 11:48 AM
lucky131969's Avatar
lucky131969
Absolutely, yet so many resist using the service manual. I don't understand why
Old Feb 2, 2008 | 12:13 PM
vettenuts's Avatar
vettenuts
Great numbers!!!!! Hubba hubba
To Harmonic Balancer Removal
