What the hell is this noise?!
Old Apr 25, 2007 | 09:54 AM
5.0_CJ's Avatar
5.0_CJ
Default What the hell is this noise?!
I'm getting frustrated... it's rather annoying and I'm stumped. Whenever I accelerate, or decelerate I hear air escaping/ "ssst" sound.. which starts loud and slowly bleeds off. Now, normally I would presume it is a vacuum leak of some sort... however it is tied in to the transmission it would seem. The reason I'm having such trouble diagnosing the sound is because with the clutch pushed in, and I downshift.. the sound appears while the clutch is disengaged... and the air noise appears while I push the car in to gear... that just doesn't make sense. The only thing I can imagine is the sound must be a clogged breather on my transmission.. I did paint the unit when I build it, but I'm certain I removed the tape from the breather. Anyone have some input?
Old Apr 25, 2007 | 10:11 AM
hellotbone's Avatar
hellotbone
Maybe somone snuck a turbo or superchager on there. Are you sure you don't have an intake leak or something? Airbox lid not sealing properly or a loose clamp?
Old Apr 25, 2007 | 10:14 AM
5.0_CJ's Avatar
5.0_CJ
I have a vararam, and I'm pretty sure it's sealed... but this shouldn't be anything on the engine... because the sound corresponds to the transmission rpm, not the engine rpm since the sound appears when the clutch is pushed in and downshifting... the rpm of the engine is at falloff/idle while you push into a lower gear.
Old Apr 25, 2007 | 10:16 AM
Zenak's Avatar
Zenak
Terminal Vette Addict
Where is it coming from? I get the same noise over my left shoulder. CHanges sound when i take my foot on and off full brake.
I assumed it was my fuel pump :-P
Old Apr 25, 2007 | 10:58 AM
5.0_CJ's Avatar
5.0_CJ
that is probably a vacuum leak/brake booster diaphragm leak. I think we most likely have different issues. The noise is most likely coming from your firewall where the booster is located... high pitched noises have tendencies to reflect off surfaces and give false perception as to where they are coming from.. when the car is running stick your head by the pedals and hit the brake.
Old Apr 25, 2007 | 12:25 PM
Zenak's Avatar
Zenak
OOO thanks. tried to help you, but you helped me :-)
I guess what goes around comes around!
Old Apr 25, 2007 | 12:41 PM
newgene's Avatar
newgene
You are describing the exact issue I used to have on my 98 M6. If I recall it would be this weird sound that would only occur in a situation as you've described. I actually lived with it for so long that I really forgot about it. This thread brings back the memory. Since then, I have added LT headers, a procharger, and Borla stingers. Needless to say, I don't notice the noise anymore. I'll bet a bunch of others have the same noise and don't realize it. It seemed to be as memorable as that ever-so-common belt chirp. BTW, that went away with the pulley reroute of the SC kit.
This was my original post to somone else's thread on it.
http://forums.corvetteforum.com/show....php?t=1085929
I guess I'm no help, but I just wanted to let you know you're not alone.
Old Apr 25, 2007 | 01:46 PM
5.0_CJ's Avatar
5.0_CJ
lol, I have longtubes and borla stingers and I still notice it! Glad to hear I'm not crazy though! I hope someone has an answer.
Old Apr 25, 2007 | 03:59 PM
yellow94coupe's Avatar
yellow94coupe
Is it just when you are accelerating or decelerating?
Try going about 30 mph and push the clutch in and see if you hear it. Then put the transmission in neutral and let off the clutch. Does it go away or change?
Old May 2, 2007 | 10:52 AM
5.0_CJ's Avatar
5.0_CJ
I have not tried this yet, but I will this evening. I'm sure it probably will do it, but I will let you know. Any idea what could cause this?
Old May 4, 2007 | 03:25 PM
yellow94coupe
If it still makes the noise then it probably isn't coming from the clutch. I'm not sure what it would be then.
Old May 7, 2007 | 04:02 PM
5.0_CJ's Avatar
5.0_CJ
well it's an air escaping/leaking noise, not clutch. I have a twin disk exedy.. it chatters/squeaks very noticably.
To What the hell is this noise?!
