Clearing memory?
Old Apr 26, 2007 | 07:33 AM
GrowLnZ06's Avatar
GrowLnZ06
Default Clearing memory?
If I have a MAF code... and its making my car run sluggish... when I replace things to try and fix it... do I need to leave my battery disconnected for a certain time frame at all? if so... how long?
Old Apr 26, 2007 | 09:20 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO! All you need to do is enter the diagnostic routine and clear the DTC from there!!
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
The reset button on the DIC control panel will serve you well!
BC
