Programming keyless entry
Old Apr 26, 2007 | 10:42 AM
M0nsterBash's Avatar
M0nsterBash
Default Programming keyless entry
Hello all..
I have a 99 C5 with the passive keyless entry. Does anyone know how to program them. My battery went dead =0(
Thanks!
-Jamie
Old Apr 26, 2007 | 12:05 PM
Itallian33's Avatar
Itallian33
just key on
press reset to clear anything
cycle through all of the options till the DIC is blank
hold the reset till FOB TRAINING appears in the DIC
then just hold the lock and unlock on the fob at the same time
Old Apr 26, 2007 | 02:50 PM
miltievette's Avatar
miltievette
or you can just hold unlock & lock at the same time until the horn sounds.
Old Apr 26, 2007 | 03:58 PM
WhtRkt's Avatar
WhtRkt
Lifetime Member
Old Apr 26, 2007 | 07:44 PM
65GGvert's Avatar
65GGvert
That will resync the fob"s signal to the car's signal, but will not program the fob to match the car. Follow the first procedure, (it's in the operator's manual), if the sync doesn't work.
Old May 6, 2007 | 02:42 AM
RogerArrambide's Avatar
RogerArrambide
The Fob Training option don´t comes, only the Tire pressure and key sync.
In other procedure I read that "turn off radio" but I donte have installed the OEM stereo.
To Programming keyless entry
