Trouble code 410
Old Apr 26, 2007 | 09:29 PM
40Below's Avatar
40Below
Cruising
Default Trouble code 410
The check engine light came on today. I used my scanner and got code 410, the book says "Secondary Air Injection System Malfunction".
Anyone have this code before? What did it turn out to be? Any ideas where I should start checking?
The car is a 2000 FRC, previous owner put K&N fresh air intake on it, other than that it's bone stock. 51,000 miles.
Old Apr 26, 2007 | 09:36 PM
Bill Dearborn's Avatar
Bill Dearborn
Here is the Service Manual diagnostic (minus schematic) info for your car. Take a look at it and see what you can do to work around not having a scan tool.
DTC P0410 Secondary Air Injection (AIR) System
Circuit Description
An AIR pump is used on this vehicle to lower tail pipe emissions on start-up. The PCM supplies a ground to the AIR pump relay, which energizes the AIR pump.
The PCM monitors the HO2S voltages to diagnose the AIR system.
During the AIR test, the PCM activates the AIR pump during closed loop operation. When the AIR is activated, the PCM monitors the HO2S voltages and short term fuel trim values for both banks of the engine. If the AIR system is operating properly, the HO2S voltages should go low and the short term fuel trim should go high.
If the PCM determines that the HO2S voltages for both banks did not respond as expected during the tests, DTC P0410 sets. If only one sensor responded, the PCM sets either a DTC P1415 or P1416 to indicate on which bank the AIR system is inoperative.
Conditions for Running the DTC
DTCs P0101, P0102, P0103, P0107, P0108, P0112, P0113, P0117, P0118, P0125, P0171-P0175, P0200, P0300, P0335, P0336, P0351-P0358, P0440, P0442, P0443, P0446, P0449, P1120, P1220, P1221, P1258, P1441 and HO2S DTCs are not set.
Fuel level greater than 12.5 percent but less than 87.5 percent.
The engine is running for greater than 2.0 seconds.
The maximum air flow is 25 g/s.
The air fuel ratio is 14.7:1
The engine load is less than 34 percent.
The ignition voltage is greater than 11.7 volts.
Engine is not operating in Power Enrichment, Decel Fuel Shut-off, or Catalyst Over-Temperature modes.
The engine is operating in closed loop for greater than 15 seconds.
The engine speed is greater than 718 RPM.
The ECT is greater than 80°C (176°F) but less than 110°C (230°F).
The IAT is greater than -2°C (28.4°F).
The fuel system is operating in fuel trim cells 1, 2, 4, 5, or 6.
Conditions for Setting the DTC
The HO2S voltage does not go below 222 mV for 1.3 seconds, when the AIR pump turns ON during closed loop operation.
OR
The short term fuel trim does not change more than a predetermined value, when the AIR pump turns ON during closed loop operation.
Action Taken When the DTC Sets
The PCM illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
The PCM turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A last test failed, or current DTC, clears when the diagnostic runs and does not fail.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Use a scan tool in order to clear the MIL and the DTC.
Diagnostic Aids
Important
Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing/replacing the module. Ensure that the gaskets are installed correctly. The gaskets prevent contaminate intrusion into the PCM.
For any test that requires probing the PCM or a component harness connector, use the Connector Test Adapter Kit J 35616-A . Using this kit prevents damage to the harness/component terminals. Refer to Using Connector Test Adapters in Wiring Systems.
AIR Pump Relay Underhood Electrical Center Terminal Identification
Front of Vehicle
Left Side of Vehicle
Ignition
B+
Right Side of Vehicle
Load
Control
If DTCs P0412 or P0418 are not set and the relay or solenoid does not respond to the scan tool commands, inspect for excessive resistance in all of the circuits associated with the AIR system.
For an intermittent, refer to Symptoms .
Test Description
The numbers below refer to the step numbers on the diagnostic table.
3. If DTCs P0412 or P0418 are set, diagnose those DTCs first.
4. The scan tool offers three modes of AIR operation, AIR solenoid, AIR pump, and AIR system. Use the AIR system selection when commanding the AIR pump, or relays. This mode ensures that the entire AIR system is responding to the scan tool commands. If DTCs P0412 or P0418 are not set and the relay or solenoid does not respond to the scan tool commands, inspect for excessive resistance in all of the circuits associated with the AIR system.
5.This step is testing for battery voltage at the AIR pump relay.
6. This step is testing for power to the AIR pump.
7.This step is testing the ground circuit for the AIR pump.
12. This step is testing for a grounded circuit between the AIR pump and the AIR pump relay.
22.A restriction in a hose or pipe before the systems divides will cause this DTC to set. Inspect for kinks or blockages from the AIR pump to the connection point where the AIR system divides.
DTC P0410 - Secondary Air Injection (AIR) System Step
Action
Values
Yes
No
1
Did you perform the Powertrain On-Board Diagnostic (OBD) System Check?
Go to Step 2
Go to Powertrain On Board Diagnostic (OBD) System Check
2
Is the AIR pump fuse OK?
Go to Step 3
Go to Step 11
3
Are DTCs P0412 or P0418 set?
Go to Applicable DTC table
Go to Step 4
4
Turn ON the ignition with the engine OFF.
Enable the AIR system with a scan tool.
Does the AIR pump turn ON?
Go to Step 8
Go to Step 5
5
Turn OFF the ignition.
Disconnect the AIR pump relay.
Probe the relay B+ supply circuit at the underhood electrical center with the test lamp J 34142-B connected to ground. Refer to Diagnostic Aids for terminal identification.
Does the test lamp illuminate?
Go to Step 6
Go to Step 16
6
Install the AIR pump relay.
Disconnect the AIR pump electrical connector. Refer to Secondary AIR Injection Pump Replacement .
Probe terminal A of the AIR pump electrical connector using the test lamp J 34142-B connected to battery ground. Refer to Probing Electrical Connectors in Wiring Systems.
Go to Step 7
Go to Step 17
7
Probe terminal B of the AIR pump electrical connector with the test lamp J 34142-B connected to B+.
Is the test lamp illuminated?
Go to Step 27
Go to Step 18
8
Disconnect the AIR pump outlet hose from the AIR pump. Refer to Secondary AIR Injection Pump Replacement .
Is air flow present at the AIR pump outlet?
Go to Step 9
Go to Step 10
9
Disconnect the vacuum hose from the AIR Shut Off Valve.
Start the engine.
Enable the AIR solenoid with a scan tool.
Is a vacuum present at the AIR Shut Off valve?
Go to Step 14
Go to Step 19
10
Inspect for a restriction/blockage in the AIR Pump inlet hoses/pipes.
If you find a restriction/blockage in the AIR hoses/pipes, repair as necessary.
Did you find and correct the condition?
Go to Step 29
Go to Step 28
11
Probe the AIR pump relay B+ supply terminal at the underhood electrical center using the test lamp J 34142-B connected to B+. Refer to Probing Electrical Connectors in Wiring Systems. Refer to Diagnostic Aids for terminal identification.
Go to Step 23
Go to Step 12
12
Probe the AIR pump relay load terminal at the underhood electrical center using the test lamp J 34142-B connected to B+. Refer to Diagnostic Aids for terminal identification.
Go to Step 24
Go to Step 13
13
Install the AIR pump electrical connector.
Install a new fuse.
Does the fuse open?
Go to Step 28
Go to Diagnostic Aids
14
Install the following components:
AIR pump outlet hose to AIR pump.
Vacuum hose to AIR Shut Off Valve.
Disconnect the AIR Shut Off Valve outlet hose.
Start and idle the engine.
Is air present at the outlet of the AIR Shut Off Valve?
Go to Step 22
Go to Step 15
15
Replace the AIR Shut Off Valve. Refer to Secondary AIR Injection Shut Off Valve Replacement .
Is the action complete?
Go to Step 29
16
Repair the open circuit that did illuminate the test lamp. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
17
Test for continuity of the circuit between the AIR pump electrical connector terminal A and the AIR pump relay using the DMM . Refer to Testing for Continuity in Wiring Systems.
If you find an open circuit repair the circuit as necessary. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
Go to Step 25
18
Repair the faulty ground connection or open AIR pump ground circuit. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
19
Disconnect the source vacuum hose from the AIR Solenoid Valve. Refer to AIR Solenoid Valve Replacement .
Is a vacuum present at the AIR Solenoid Valve?
Go to Step 20
Go to Step 21
20
Connect the source vacuum hose to the AIR Solenoid Valve.
Disconnect the vacuum hose to the AIR Shut Off Valve at the AIR Solenoid Valve.
Enable the AIR Solenoid Valve with a scan tool.
Is a vacuum present at the AIR Solenoid Valve outlet?
Go to Step 21
Go to Step 26
21
Repair the restriction/blockage or damage to the vacuum hose.
Go to Step 29
22
Repair the restriction/blockage or disconnect in the AIR hose between the AIR Shut Off Valve and the point where the system branches to both side of the engine.
Go to Step 29
23
Repair the short to ground in the ignition feed circuit between the fuse and the relays. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
24
Repair the short to ground in the circuit between the AIR pump relay and the AIR pump. Refer to Wiring Repairs in Wiring Systems.
Go to Step 29
25
Replace the AIR pump relay. Refer to Secondary Air Injection Pump Relay Replacement .
Go to Step 29
26
Replace the AIR Solenoid Valve. Refer to AIR Solenoid Valve Replacement .
Go to Step 29
27
Inspect for poor connections at the AIR pump electrical connector. Refer to Testing for Intermittent and Poor Connections in Wiring Systems.
If you find a poor connection repair the terminal as necessary. Refer to Repairing Connector Terminals in Wiring Systems.
Go to Step 29
Go to Step 28
28
Replace the AIR pump. Refer to Secondary AIR Injection Pump Replacement .
Go to Step 29
29
Select the Diagnostic Trouble Codes (DTC) option and the Clear DTC Information option using the scan tool.
Start the engine and idle at the normal operating temperature.
Select the Specific DTC option under the Diagnostic Trouble Code (DTC) option using a scan tool.
Operate vehicle within the Conditions for Running this DTC as specified in the supporting text, if applicable.
Does the scan tool indicate that this test failed?
Go to Step 2
Go to Step 30
30
Select the Capture Info option and the Review Info option using the scan tool.
Are any DTCs displayed that you have not diagnosed?
Go to the applicable DTC table
System OK
Bill
Old Apr 26, 2007 | 09:58 PM
40Below's Avatar
40Below
Cruising
Thanks for all the great info.
To Trouble code 410
