Brake Caliper Bolts
Old Apr 29, 2007 | 09:00 PM
TNT C5's Avatar
TNT C5
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Originally Posted by 2000BSME
no, just don't need a dialog about how wrong it is to run a bolt without loctite. You started that dialog after I disclosed the reason why I didn't use loctite. We can end that dialog just as soon as you drop it, Mr. Know it all.
Get a grip...junior. I said nothing about you not using Loctite. I merely said I thought a better suggestion to our fellow poster would be to use blue, not red. The rest of whatever has you all jacked up is a figment of your imagination, not a product of anything I posted. Sorry.
I had to play around with the hose routing for another half hour today... in spite of all my efforts I still couldn't keep the lines away from the headers...
I think I have it all ironed out now though. I'll post the final pics later, after I've cooled off a bit...and I'm sure I'll be in a better mood then.
I certainly hope you are in a better mode soon. You're starting to give everyone a snicker and you're probably not as big a donkey as you are coming across!
Old Apr 30, 2007 | 11:25 PM
striper's Avatar
striper
A friend of mine who is a GM dealer shop foreman told me the same thing. They want you to replace the bolts because liability-wise, they have to assume most people won't put a locking compund on the bolts when re-using. I put on "blue" Loc-tite and have never had a problem.
