thermostat question
What you have to remember is that you also need to have your fans re-programmed to come on earlier to take advantage of the lower t-stat otherwise it's a waste of time. My 1st fan comes on at about 178 second fan is on about 188-190 I believe.
Effects on my car. Overall the car runs great. I can be in 90 degree ambient temps in stop and go traffic, hottest my coolant will get is about 188-190, and my oil will get up to about 205, maybe a bit more..in stop and go traffic the fans will pretty much stay on until you get above 45mph in that kind of temp.
Cruising with 80-90 degree temps out, oil stays around 200, coolant at about 175-180.
Now, the only downside so far I can see, is that during the winter in very cold temps out below say 32F, the oil does not get above 180 or 185, which is not ideal, but wont hurt if you are not romping on the motor. I don't drive my car hardly at all in the winter so it does not really matter.
With the proper tuning etc.. it's fine. I would only do this if you decide to add other mods..if you are running a stock set up, no real reason to change as you don't really gain anything.
Hope this helps.
Same here....AND...no issues with the heater not being hot enough for the 5 or 6 times I drive during winter months...go 160 IMO..
