Lifter noise? Several questions...
Old Apr 28, 2007 | 01:55 AM
500hp's Avatar
500hp
Default Lifter noise? Several questions...
I have been catching bits and pieces of other threads involving lifters, and these Cadillac Racing Lifters for curing valvetrain noise.
What is actually making the noise we are hearing? The lifters themselves, or the rockers and/or pushrods?
I just installed a TSP 233/239 (on a 113 LSA) with around .600" lift, and am hearing what sounds like valvetrain noise, from inside the 'cockpit'. This is on my '01 Z06, with 110k miles. I was told by TSP, and other tuners, to use a pushrod that allowed about 1 AND 1/4 turns past zero lash for lifter preload. 7.450" was recommended, and turned out to be about right. It was also mentioned that anything less could result in increased valvetrain noise.
If, by chance, 7.450" was too long, would that also cause noise or oiling issues?
Like many of TSP's grinds, my cam is designed to work on a stock head/piston application. Does the inherent lobe profile for such an aggressive cam lend itself to more valvetrain noise--Maybe 'valve to seat' noise on a higher mileage engine?
Do the stock rockers simply NOT like anything approaching .600" lift?
I also have TSP headers. Do headers somehow 'amplify' valvetrain noise on these cars?
I am prepared to "live with it" as long as we can agree that I am not hurting anything (or losing performance/power).
Thanks, Joel.
Old Apr 28, 2007 | 03:19 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
See Quote..
Originally Posted by 500hp
I have been catching bits and pieces of other threads involving lifters, and these Cadillac Racing Lifters for curing valvetrain noise. For the regular street guy, I see ZERO purpose for going anything over the LS7 lifters. New isnt ALWAYS better.What is actually making the noise we are hearing? The lifters themselves, or the rockers and/or pushrods? Could be the lifters, springs OR the pushrods. What springs did you install??
I just installed a TSP 233/239 (on a 113 LSA) with around .600" lift, and am hearing what sounds like valvetrain noise, from inside the 'cockpit'. This is on my '01 Z06, with 110k miles. I was told by TSP, and other tuners, to use a pushrod that allowed about 1 AND 1/4 turns past zero lash for lifter preload. 7.450" was recommended, and turned out to be about right. It was also mentioned that anything less could result in increased valvetrain noise. A pushrod that is too long OR too short can cause valvetrain noiseIf, by chance, 7.450" was too long, would that also cause noise or oiling issues?
Do the stock rockers simply NOT like anything approaching .600" lift? There are MANY guys that are running stock rockers at .600 lift. I've never heard of any major complaints at that lift.I also have TSP headers. Do headers somehow 'amplify' valvetrain noise on these cars?
I am prepared to "live with it" as long as we can agree that I am not hurting anything (or losing performance/power). IF you have everything set up correctly, you are probably just hearing the inherit sewing machine noise that is associated with a cam/springs swap..Thanks, Joel.
Old Apr 28, 2007 | 07:09 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Fast Sewing Machine
I've got a fast sewing machine also. After the H/C swap last summer I was amazed at the noise.
I learned to live with it. Now I'm waiting for the Caddy lifters to install in my 402. I hope they make it quiter.
Bob K.
Old Apr 28, 2007 | 08:06 AM
vettenuts's Avatar
vettenuts
What is actually making the noise we are hearing? Cam ramp rates will play a major role in the noise, as will the valve train. The lifters themselves, or the rockers and/or pushrods?
If, by chance, 7.450" was too long, would that also cause noise or oiling issues? The major issue would be bottoming the lifter internally and holding the valves open that can result in burnt valves. The only correct way to obtain a proper lifter preload is to measure with an adjustable pushrod since each motor is slightly different.
Like many of TSP's grinds, my cam is designed to work on a stock head/piston application. Does the inherent lobe profile for such an aggressive cam lend itself to more valvetrain noise--Maybe 'valve to seat' noise on a higher mileage engine? The lobe profile yes, the valve to seat no unless the cam is slamming down the valve but any proper cam design should not do this. The lobe design is such that the valve is accelerated to the seat and then set down on the seat. Of course, the rest of the valve train needs to keep up (not lose contact) for this to work properly.
I also have TSP headers. Do headers somehow 'amplify' valvetrain noise on these cars? Headers will allow more noise to be transmitted from the valve train. If you ever put a stethoscope on a motor you can hear theres a lot of noise going on in there. The rockers have been used successfully by a lot of guys with aftermarket cams. I personally don't like the wipe pattern and you have to be careful where it is contacting the valve stem. I found a few of mine were contacting towards the side of the rocker and changed them out for a full roller. Some people have reported that a full roller has quieted things down, but I would make sure your geometry is correct first, then consider other options. Things to check are wipe pattern and pushrod length and go from there.
Thanks, Joel.
I swapped out to Morel lifters when I put my heads in the car. They were designed to sit lower in the lifter bore for an aftermarket cam (the additional lift is obtained by decreasing the base circle) and have better materials than the GM lifters. The roller is also slightly larger.
Old Apr 28, 2007 | 08:07 PM
500hp's Avatar
500hp
Thanks guys. Great answers!
I am using the Patriot/PRC Dual Springs for .650" lift (the Golds ?), with titanium retainers.
I have anywhere from 35psi to 55psi for oil pressure. Car seems to run great (once I get it out on the highway, after about 10 minutes) with a partial/temporary tune, but I am trying to keep it below 6,000 RPM until I get the car dyno-tuned on May 9th--just trying to work all the 'bugs' out before then.
The noise is very similar to my old, .600" lift solid roller cammed 383 LT4 (with CC ProMag 1.6 RRs, and headers, of course).
I can't imagine a 7.425" pushrod would make a noticeable difference, though I wouldn't be against trying this, if someone were to 2nd this motion (?).
I am certainly not too concerned about some extra noise, as many a worthwhile mod usually brings along some kind of concession/compromise.
Old Apr 29, 2007 | 12:42 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
My trans am also makes that same noise. I thought that maybe I had some bad lifters so I yanked the heads and put new lifters in. Still makes the same sound. I use the 7.425 pushrods. I was worried about it for a while but from what i hear the noise has alot to do with the aggressive lobes so i just learned to turn up the radio.
Old Apr 29, 2007 | 11:11 AM
RED99's Avatar
RED99
Here are a few things that can make ticking noise:
Headers themselves
Header gasket leaks
Low oil pressure.
sloppy lifter to bore clearance
Piston to cyl. wall slap.
To Lifter noise? Several questions...
