Error Code C1225?
Old Oct 18, 2001 | 08:26 PM
HIGHRPM's Avatar
HIGHRPM
Default Error Code C1225?
what is error code C1225?
Old Oct 18, 2001 | 11:11 PM
intel55's Avatar
intel55
Default Re: Error Code C1225? (HIGHRPM)
EBTCM internal malfunction
electronic brake control maodule.
The condition is set when an internal EBTCM malfunction exists.
If there are no bad wires or terminals on it, then it looks like the EBTCM module will need to be replaced. :cheers:
Old Oct 19, 2001 | 03:20 AM
HIGHRPM's Avatar
HIGHRPM
Default Re: Error Code C1225? (intel55)
Where can I find a list of all the error codes?
Old Oct 19, 2001 | 03:54 AM
intel55's Avatar
intel55
try the tech tips section. Taht should list a one line description of what they are I think. I get my info form the service manuals which go into great detail. :cheers:
Old Oct 19, 2001 | 07:31 AM
davidfarmer's Avatar
davidfarmer
Error code C1225 is usually set when some other sensor is set. Did you have any other faults. For instance, when I have had speed-sensor go out, it will set a code for that specific wheel, then the C1225 will ALSO set.
Dave
Old Oct 19, 2001 | 11:31 AM
Steve-O's Avatar
Steve-O
Here are a couple of sites (or pages)
http://www.corvetteplanet.com/search.cfm
http://97vette.com/howto/codes/index.html
Old Oct 19, 2001 | 04:03 PM
HIGHRPM's Avatar
HIGHRPM
Steve-O....The 2 websites you listed have different results....one said that a C1225 code is the RF wheel sensor (97vette.com), the other has a LF wheel sensor problem. Anyone know which it is?
Old Oct 19, 2001 | 04:34 PM
Steve-O's Avatar
Steve-O
HighRPM,
I wish I could be of more help, but I just had a few of these sites tagged in my favorites, I don't know anymore than that, (but here is a website that a forum reader has that could help).
http://corvetteforum.net/c5/c5_tech/
Good luck !
for more tsb,etc)
Old Oct 19, 2001 | 04:53 PM
HIGHRPM's Avatar
HIGHRPM
Default Re: Error Code C1225? (Steve-O)
Thanks Steve-O.....I don't have a factory manual to check this out.....anyone know for sure what a C1225 code is?
Old Oct 19, 2001 | 05:26 PM
intel55's Avatar
intel55
opps I think I am dislexic (spelling sucks too) I do not know why I posted the other code.
Oh well
c1255 LF excessive wheel speed variation
description: "the speed sensor used on this verhicle is a single point magentic pickup. This sensor produces an AC signal that the EBTCM uses the frequency from to calculate wheel speed."
conditions for setting the DTC: "The DTC can be set anytime the brake is not depressed and no wheel speed sensor hardware DTCs are present, and the EBTCM sees a wheel speed variation of more than 9 mph for 2.5 seconds."
Actions taken when the DTC sets: "ABS/TCS Active ahndling (if equipped) are disabled.
Idicators thatturn on: ABS indicator, car icon (TCS)
Messages displayed on DIC
serivce ABS
service traction system
srevice active HNDLG (if equpped)
Diagnostic aids: check all wiring and connections or isulation.
Old Oct 19, 2001 | 05:29 PM
intel55's Avatar
intel55
Possible actions
the wheel speed sensor could be bad
the wiring may have damage (shorts, loose fitting, etc).
the EBTCM could be bad
Old Oct 19, 2001 | 07:29 PM
HIGHRPM's Avatar
HIGHRPM
thanks intel55. the dealer replaced the LF speed sensor a few days ago, but I still get the C1255 code. It must be one of the other problems you listed. thanks again.
Old Oct 19, 2001 | 07:56 PM
intel55's Avatar
intel55
could be or he forgot to clear the code. Try clearing the code. See if it is a history or current code.
To Error Code C1225?
