Overheating problem, help!
Old May 11, 2007 | 02:03 PM
Jeff48's Avatar
Jeff48
6th Gear
Default Water Pump
Anyone ever hear about the water pump coming apart? It does seem like the Radiator is much cooler than the engine even after installing a new T-stat?
Old May 11, 2007 | 02:08 PM
buyer_1's Avatar
buyer_1
may seem like a dumb question, but is there any information/ pictures on the thermostat change procedure ? I couldnt really find a thread where it is detailed on the forum.
Old May 11, 2007 | 07:06 PM
stormrider's Avatar
stormrider
Read this thread and see if it fits for your problem (I hope it doesn't)
http://forums.corvetteforum.com/show....php?t=1696062
Old May 12, 2007 | 02:15 AM
AnotherPewterVette's Avatar
AnotherPewterVette
im having the same problem on my 99 stock engine coupe. it will shoot up to 260 real quick and then back down to 203 or so like it usually runs. i do have an oil change warning showing tho, and had that planned for tomorrow anyway. We think its possily the thermostat whick is a very simple fix. or it could be the temp sensor, b/c of how fast the temp guage is moving. There is no way that the h2o temp could change from 260 to 205 in seconds, just not possible. i read the thread on the clogged radiator, a possibility but prolly not. So tomm morn i will change oil, new thermostat, new temp sensor, flush radiator and report back.
And all this stress is on top of me taking a 750 mile trip from texas to iowa on thursday!!
Old May 12, 2007 | 11:13 AM
AnotherPewterVette
TTT
Has anyone had simular problems?
Old May 12, 2007 | 11:42 AM
-Blue Vette-'s Avatar
-Blue Vette-
I had the EXACT same problem with my 01. I changed my water pump and now it's fine. In my case, the pump bearing was going out.
Old May 12, 2007 | 04:54 PM
Jeff48's Avatar
Jeff48
6th Gear
Default Bad Water Pump 02 Over Heat Prob
Well they put a new pump in and problem is gone. I want to take the old pump apart to see what failed. I'll let everyone know when I do. Thanks for all the good suggestions.
Old May 12, 2007 | 05:10 PM
AnotherPewterVette
ok my car ran fine all morn and like 15 miles no problems. So i changed the oil and installed a new thermostat(180 stock temp) and new coolant. drove a lil while and while idling thru a parking lot it overheated again. the temp needled goes from 205 straight to 260 and stayed there. But i think it is something electrical. like a short or something. cuz it heats up way too fast. then the car would idle funny, "check guages" would flash and A/C turns on and off. The car doesnt steam or loose coolant to the ground. and the oil temp guage says 208-212, which should be the same as the coolant temp.WTF??
Has anything like this ever happened to anyone?? any help with a bad ground or simular symptoms would be great. thanks
Old May 12, 2007 | 10:56 PM
gpracer1's Avatar
gpracer1
Look at your invoice and Ill bet they put in a new thermostat also.
Old May 12, 2007 | 11:00 PM
jtrundle's Avatar
jtrundle
The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
Bill
HOLY CRAP! I cannot beleive this post! If my car was getting 226*, I would be freaking out! I guess this is normal for the vette? In my Grand Prix GT or my 454SS pickup, I have never seen temps over 210*. What I am saying is I guess I am not use to seeing temps this high. Glad I read this post.
Old May 13, 2007 | 12:52 PM
AnotherPewterVette
i think i found my problem. the ground in this pic(not my car) was very loose, so i cleaned it real good and then did the other side the same. So far so good!!
Old May 13, 2007 | 01:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hey,,,,thats my picture!!! Glad it helped you!!! If you havent done ground maintenance, it would be a good idea!
BC
Old May 13, 2007 | 10:54 PM
  #33
AnotherPewterVette
well im back in the same boat it wasnt just a ground afterall, cuz i drove for about 20-30 miles today and the temp guage pegged out to 260 again. and back and forth from normal to 260. i just dont get it!
Old May 13, 2007 | 11:33 PM
  #34
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check the sensor for a good connection!
BC
Old May 13, 2007 | 11:50 PM
  #35
AnotherPewterVette
BC
thanks, i was to replace the sensor but figured it was good b/c it works properly most the time. When this happens the DIC say "coolant temp xxx" has anybody seen that before? and the oil temp sstays at about 203-210 during all of this.
Old May 14, 2007 | 12:40 AM
  #36
NOS500's Avatar
NOS500
I would try replacing the sensor. Good Luck!
Old May 14, 2007 | 11:17 AM
  #37
T VETTE's Avatar
T VETTE
I never believe any of that 100,000 mile or 5 year stuff for coolant, spark plugs or filters etc. It's all too cheap not to change it. I at least cut it in half for time or miles.
Proof again........
To Overheating problem, help!
Old May 14, 2007 | 10:36 PM
  #38
AnotherPewterVette
Today i did replace the engine temp sensor. Which was very easy for the DIYer. So far so good, only more driving will tell if the problem persists. Thanks everyone.
Old May 16, 2007 | 03:24 PM
  #39
buyer_1's Avatar
buyer_1
This morning, I took my car in for repairs. They told me its a faulty pump. They will replace the thermostat as well. Estimate $670.
Lets hope thats the end of that.
Old May 17, 2007 | 06:10 PM
  #40
buyer_1's Avatar
buyer_1
So I havent got my car back yet. I am also wondering how you would know if its just a bad thermostat vs. a bad water pump ? The coolant wasn't circulating in the car and that could be due to either couldn't it ?
Any opinions ?
Thanks!!
