Leaking Steering Rack
Old Apr 29, 2007 | 11:56 PM
LLVETTE's Avatar
LLVETTE
Default Leaking Steering Rack
It looks like I have a leak on the pass side of the rack. The boot is ripped and it's wet in that area. Can anyone help with the removal. I searched and didn't find a thread that detailed the removal of the rack to repair or replace...Oh, that brings up another question, can it be fixed or will I have to open the wallet?...Thanks in advance.
Old Apr 30, 2007 | 02:07 AM
Bill Dearborn's Avatar
Bill Dearborn
If you are planning on doing it yourself you should spring for a set of GM Service Manuals. Here is the procedure minus the pictures and the hot links to other locations in the manual that you will have to turn to.
Power Steering Gear Replacement
Removal Procedure
Tools Required
J 42188 Ball Joint Separator
Place a drain pan under the vehicle and drain the power steering fluid.
Disconnect the intermediate shaft lower coupling from the power steering gear. Refer to Intermediate Steering Shaft Replacement in Steering Wheel and Column-Tilt.
Disconnect the power steering pump inlet hose (2) from the power steering gear.
Raise and suitably support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Disconnect the power steering cooler pipe from the gear.
Remove the power steering cooler from the vehicle.
Disconnect both outer tie rod ends from the steering knuckles. Refer to Tie Rod End Replacement - Outer .
Disconnect the electrical connector for Magnasteer®.
Remove the stabilizer shaft from the crossmember. Refer to Stabilizer Shaft Replacement in Front Suspension.
Disconnect the wiring harness clips from the crossmember.
Disconnect the brake pipe from the crossmember fastener clips.
Remove the steering gear mounting bolts and nuts.
Using hand tools only, LOOSEN, Do Not Remove, the four crossmember mounting nuts 10 mm (0.394 in).
Remove the power steering gear from the vehicle through the left wheelhouse opening by rotating.
Installation Procedure
Install the power steering gear to the vehicle through the left wheelhouse opening.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the power steering gear mounting bolts and nuts. Tighten
Tighten the power steering gear mounting nuts to 100 N·m (74 lb ft).
Install the crossmember mounting nuts. Tighten
Using hand tools only, tighten the crossmember mounting nuts to 110 N·m (81 lb ft).
Fasten the brake pipe to the crossmember fastener clips.
Install the stabilizer shaft to the vehicle. Refer to Stabilizer Shaft Replacement in Front Suspension.
Connect both outer tie rod ends to the steering knuckles. Refer to Tie Rod End Replacement - Outer .
Connect the intermediate shaft lower coupling to the power steering gear. Refer to Intermediate Steering Shaft Replacement in Steering Wheel and Column-Tilt.
Connect the electrical connector for Magnesteer®.
Connect the wiring harness clips to the crossmember.
Install the power steering cooler to the crossmember.
Connect the power steering cooler fitting to the power steering gear. Tighten
Tighten the power steering cooler fitting to the power steering gear to 27 N·m (20 lb ft).
Connect the power steering gear inlet hose (2) to the power steering gear. Hold the hose against the steering gear while tightening the fitting. Tighten
Tighten the power steering gear inlet hose fitting to the power steering gear to 27 N·m (20 lb ft).
Remove the drain pan.
Install the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Lower the vehicle.
Install the intermediate shaft shield. Tighten
Tighten the intermediate shaft shield clamp to 3.5 N·m (32 lb in).
Refill the power steering fluid reservoir.
Bleed the power steering system. Refer to Bleeding the Power Steering System .
Check and adjust the front wheel toe setting. Refer to Front Toe Adjustment in Wheel Alignment.
Perform the SWPS plausibility test. Refer to Steering Wheel Position Sensor Plausibility Test in ABS Brakes.
Bill
