Battery draining issue
Old Apr 30, 2007 | 01:44 PM
mrw173's Avatar
mrw173
St. Jude '03-'04-'05-'06-'07-'08-'09
Default Battery draining issue
It just started and I can't seem to find it. When I connect and disconnect the battery I can feel and hear something making a clunking sound. I have removed the fuses from both light motors and disconnected ther weatherpack connectors and it still makes the noise. I can actually feel it when I touch the side of the light motor. Any idea what else can be inside there, this is on the pass side. Thanks
Old Apr 30, 2007 | 08:02 PM
Suprfun's Avatar
Suprfun
What you're hearing is most likely the headlight module. It's located on the right side just behind the headlight opening and has two plugs connected to it. It controls the up/down of your headlights. Mine clicks when I connect and disconnect the battery. Just went through the same ordeal with the battery draining, ended up being a defective 1 year old Delco battery. It would only take a surface charge and would go dead in about 24 hours. If you haven't done/changed anything on your car that might cause the problem I would put a known good battery in and see if it goes dead. The C5 has some parasitic drains normally, also they're not like the older 70's 80's cars where you could just hook a voltmeter in series on the neg battery cable and neg post and if it showed battery voltage (12 volts or more) you knew you had a short. Be careful diagnosing as the electrical systems/modules are very sensitive to current surges, sparks, ect... Good luck finding your problem.
Old Apr 30, 2007 | 08:50 PM
mrw173's Avatar
mrw173
This is a one year old Optima red top. Everything has been fine, this problem just started. The battery takes a charge just fine. My VOM only reads up to 250MA and it gets pegged immediatly so I don't leave it there as I have no idea what the draw actually is, it must be huge though as I used a 10ga piece of wire with alligator clips between the negative terminal and the negative wire for ease of testing and it smoked instantly. I pulled every fuse and relay from under hood and no change.
Old Apr 30, 2007 | 08:57 PM
DPG's Avatar
DPG
St. Jude Donor '06
When you hear that clicking noise, its just some of the relays that are opening or closing. Normal noises there when you connect and disconnect the battery. Check some of your grounds. Bill Curlee has some threads about finding bad grounds.
Old Apr 30, 2007 | 09:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mike
There are NUMEROUS post on current draw and how to troubleshoot and correcting this issue. I have posted twice this month on this very topic. Look under post from me or search C5 Tech under CURRENT DRAW
Bill Curlee
Old Apr 30, 2007 | 09:22 PM
mrw173's Avatar
mrw173
Originally Posted by Bill Curlee
Mike
Bill Curlee
Thank you, searching..................
Old Apr 30, 2007 | 09:49 PM
Suprfun's Avatar
Suprfun
Just a shot in the dark here but have you installed anything or made any changes to the car lately? Exhaust work? Wire melted on exhaust? You can unplug the headlight module to eliminate it if it sounds real loud. Mine just makes an audible click when hooking up the battery. Sorry not much help here!
Old Apr 30, 2007 | 09:56 PM
mrw173's Avatar
mrw173
No changes of any kind. I did the search and will try some of those things tomorrow but I really don't think the problem is a bad ground. There is enough draw to melt a 10 gage wire when placed inbetween the battery (neg) and the neg connector. I pulls down the battery overnight.
Old Apr 30, 2007 | 10:15 PM
Suprfun's Avatar
Suprfun
With that kind of draw it sounds like a short of some kind. Another thing to try is to unplug the alternator and also unhook the heavy red wire from it. That would eliminate the alternator from being the cause of a short. You can take the nut off the connection on the under hood fuse box and separate the connections there and see if that will help you isolate it.
Old Apr 30, 2007 | 10:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
HOLY ****SKIES! Thats a LOT of amps in the OFF/SLEEP MODE!!!! You need to start troubleshooting by deviding the two fuse boxes. The B+ connection on the engine fuse box has TWO wires.
One is the battery wire and the other is the wire that comes from the passengers fuse box. Remove the wire that feeds through to the passengers fuse box.
Hook that wire back up and see if you have the same current draw.
WOW!
BC
You will need to
Old Apr 30, 2007 | 10:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
COOL,,,,you and I are on the same sheet of music!
BC
Old Apr 30, 2007 | 11:07 PM
mrw173's Avatar
mrw173
Thank you Sooooo much, now it seems we are going to get somewhere. I have disconnected the battery for the night and will try that in the morning.
Old May 1, 2007 | 10:26 AM
mrw173's Avatar
mrw173
WOW!
BC
You will need to
I have disconnected the inside fuse box from the B+ connector and it is definatelly on the inside of the car as I get a very low readung with it removed. I have disconnected both leads from the B+ post and connected them together and the problem is back. I will start pulling fuses from inside the car.
Old May 1, 2007 | 05:22 PM
mrw173's Avatar
mrw173
The amperage draw was such that it fried my VOM. I will get a new one tomorrow
Old May 1, 2007 | 07:22 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
What ever is comsuming that much current has to be H O T!!! There are only a few things that I can think of that would cause that much draw:
The passengers or drivers seat motors being stuck on. Check the multifunction switch and see if it is centered.
The rear window defroster.
The alternator diodes being bad and drawing current when the engine is OFF
The headlight control module. It under the passengers headlight on the frame header bar.
Feel all of these and see if antof them are HOT.
Bill
Old May 1, 2007 | 09:19 PM
mrw173's Avatar
mrw173
Bill
I bet you are right here!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
This is where I am hearing noise.
How can I get at this module though, it looks to be inside an area that is inaccessible.
Old May 1, 2007 | 09:27 PM
Suprfun's Avatar
Suprfun
If you have small hands you can go in from the top on the right side (standing in front of the car facing the light) of the light (with the light in the up position) to unplug the module. It has two plugs going to it. Unhook the battery before doing this so the light doesn't close when you unplug it with your hand in there! Might give you a little more room with the plastic headlight surround removed also.
To Battery draining issue
Old May 1, 2007 | 10:10 PM
mrw173's Avatar
mrw173
Thanks, I will try this tomorrow. Too late to attempt it tonight.
Old May 1, 2007 | 10:21 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I jack up the front of the car and remove the close out panel under the front. You can access it there easily.
BC
Old May 2, 2007 | 10:56 AM
5.0_CJ's Avatar
5.0_CJ
I'm having this same issue.. I'm definately
Mine is slow.. I thought it was my battery so I replaced it with an optima red top, but the drain is still there. I *thought* it was an interior light, so I readjusted the glove box which did have a light on, and then I flipped the breaker on my stereo system.. I thought the cap was doing it.. but it's still there... very slow drain.. not sure what the hell it is.
