K&N or Vararam filter
Old May 2, 2007 | 10:06 AM
19vette91's Avatar
19vette91
Default K&N or Vararam filter
What's your opinion. On my 02 Zo6 I have the Vararam VB 2 Installed and not sure what air filter to use. Vararam says that their new filter flows better than the K&N air filter (no, it's not their old foam filter)
Old May 2, 2007 | 11:07 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
If it flows better it just bypasses more dirt.
Old May 2, 2007 | 12:28 PM
BanditDude's Avatar
BanditDude
The green or grey filters will be fine, and they're similar construction to the K&N. The green one flows better because it's thicker (more surface area).
Old May 2, 2007 | 12:51 PM
BowTieRocket's Avatar
BowTieRocket
Old May 2, 2007 | 08:10 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
If I'm not mistaken, I think the B2 filter in the new units is made by K&N. There was a post about this, and about oiling the filter before you drove the car with the new Vararam installed. It was within the last week, so you might do a search and confirm this. In any case, all the paper filters can be cleaned and reoiled the conventional way, as far as I know, and they are probably pretty much all the same.
Old May 3, 2007 | 12:10 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
You can clean the filter like a K&N but the VaraRam filter is not made by K&N.
Old May 3, 2007 | 01:45 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
So if my B2 has the black foam filter I am sucking mud? LOL I oiled it so hopefully it will catch particles better.
Cajun
Old May 3, 2007 | 08:16 PM
Ralphyboy's Avatar
Ralphyboy
Thanks for the explanation Cajundude .I thought K&N made this filter, but apparently I'm wrong.However, it is good to know that I was correct about the cleaning and oiling process and that they are the same.Wouldn't want to steer anyone wrong.By the way, thanks again for your install instructions. They saved my butt.
To K&N or Vararam filter
