Throttle Body = added HP?
Old May 2, 2007 | 09:06 PM
Vette'n04's Avatar
Vette'n04
Default Throttle Body = added HP?
ON Ebay there is a LS1 throttle body offered for sale which CLAIMS to add 15-20 HP to a stock engine. The details are as follows:
-78mm adds 350cfm over stock
-Brass throttle blade 50% thinner than stock
-semi polished air inlet
-will NOT throw any codes (engine will adjust to higher cfm's)
-power is felt in low and mid range
-1/2 hour install
-$150.00 cost + $90.00 core charge
Anybody here think any of his is true? Do you think it's a good deal?
As always, thanks in advance for your help!
Old May 2, 2007 | 09:32 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Save your money.
Old May 3, 2007 | 08:38 PM
donkelso's Avatar
donkelso
As a comparison, I picked up an 80mm BBK throttle body on EBAY for cheap and replaced mine. Throttle response is a little crisper and more responsive, but I don't think it produces any more HP. I wouldn't spend the money again.
Old May 3, 2007 | 09:54 PM
JEEP/C5's Avatar
JEEP/C5
I would say its good for 5 to 7 hp at the most. The main difference in the throttle response.
Old May 3, 2007 | 10:59 PM
C5XTASY's Avatar
C5XTASY
This is true. However, it does enhance the driving experience, IMHO.
Ed
Old May 4, 2007 | 11:17 AM
Gordy M's Avatar
Gordy M
The stock TB will flow enough for a 500 crank hp car, how can putting a larger TB on a car make any difference. You can only get so much air into the cylinder on each revolution. A colder charge will give you a more dense mixture for more hp, a larger TB will not.
Old May 4, 2007 | 11:50 AM
Cajundude's Avatar
Cajundude
For the record, I am putting down 800 with the stock tbody and maf.
Old May 4, 2007 | 06:00 PM
EStreeter's Avatar
EStreeter
-1/2 hour install
You can send you stock TB the Mark Shaner at S2 Performance and get a real nice porting job for a lot less than that and a lot of people can offer first hand testimonial to the quality of his work and the change in their cars after the install. You can also just order a ported TB from Mark and then send him you stock one as a core exchange. Why reinvent the wheel - go with a known quality mod.
Old May 4, 2007 | 09:24 PM
Vette'n04's Avatar
Vette'n04
Thanks for the info, I think I'll take this advise.
Rich
To Throttle Body = added HP?
