Back up lights dont work
Old May 2, 2007 | 11:09 PM
1999WHITEFRC's Avatar
1999WHITEFRC
Default Back up lights dont work
Old May 2, 2007 | 11:41 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I would look at the switch itself. Its mounted on the left side of the transmission. See if its plugged in all the way and if so, put a meter across it and see if its got continuity when you are in reverse.
Old May 3, 2007 | 08:23 AM
65GGvert's Avatar
65GGvert
I've never physically checked, but according to the service manual it's on the right (if the arrow points to the front of the car as the manual states). Anyway, it's a plug on the side of the transmission. If it's not connected, you'll get your symptoms. The switch may be bad and just unscrews, but if it stopped working when you did your swap, I'd check the plug and wiring. You may have pulled a wire out of the connector.
Old May 3, 2007 | 09:39 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Very common problem. They dont seem to last very long for a simple switch. I wonder if it is more fine quality DELPHI stuff??
My 98 had the exact same symptoms. It was that switch. Easy do it your self project.
BC
Old May 3, 2007 | 10:11 AM
The Big Guy's Avatar
The Big Guy
St. Jude Donor '12-'13-'14
99 6mm coupe I had the same problem that occured during warranty. Watched the stealership R. & R. the switch. 6mm is a no brainer job. Cost of switch is nominal. Good luck !
Old May 3, 2007 | 04:15 PM
1999WHITEFRC
Old May 3, 2007 | 08:32 PM
dgrant3830's Avatar
dgrant3830
I couldn't remember if it was the left or right side and I'm at work so manuals are at home.. had %50 chance of getting it right! Thanks for correcting me.
Old May 4, 2007 | 02:40 PM
Roadking60455's Avatar
Roadking60455
Default Contiuity test is'e always correct
I had the same problem and checked the switch with an ohm meter and found continuity. Since I culd find no other problems I changed the switch anyway and voila, the backup lights work.
Old May 4, 2007 | 04:21 PM
JC in XTC5's Avatar
JC in XTC5
BC
Common issue, easy fix. You can do it yourself.
Old May 4, 2007 | 05:51 PM
LoneStarFRC's Avatar
LoneStarFRC
My '99 had the same problem early on. After replacement, no more problem for the last 8 yrs.
Old May 7, 2007 | 07:06 PM
dads01dream's Avatar
dads01dream
I have the exact same problem currently, the only thing is my tranny is an A4. Could somebody tell me how to track down this issue on an A4? Any advice/help/pictures would be great!
Thanks.
To Back up lights dont work
