weird noise when going more then 75 mph
Old May 5, 2007 | 04:34 AM
borisshnitkin's Avatar
borisshnitkin
Default weird noise when going more then 75 mph
my front passenger side rim has a bent rim on the inside. the rims are all balanced. i was driving today and i heard a weird noise after 75 mph. its almost like a drone but i really have no idea what it can be. can the noise be because of the bent rim?
Old May 7, 2007 | 08:01 AM
dhirocz's Avatar
dhirocz
Doubtful. That should cause a vibration if anything, not a drone. My guess if by the time a bent wheel would be bent enough to cause a drone, you'd be missing all your teeth
Probably a wheel bearing noise or some sort of drone from the engine. Is it speed dependant or RPM dependant?
Old May 7, 2007 | 06:53 PM
Lew W's Avatar
Lew W
Didja ever think at was the poolce?
Old May 7, 2007 | 07:17 PM
borisshnitkin
it only happens when im traveling 75 mph and more and it gets louder past 75
Old May 7, 2007 | 07:34 PM
borisshnitkin
could it be the wheel bearing because i only hear the noise after 75mph?
Old May 7, 2007 | 11:56 PM
kevin40zx's Avatar
kevin40zx
Does the noise stop or get quieter when you gradually turn right or left at those speeds?
Old May 8, 2007 | 12:01 AM
FRC Jon's Avatar
FRC Jon
hmmm
Old May 8, 2007 | 05:12 PM
borisshnitkin
i just drive straight without turning and it gets louder past 75mph
Old May 9, 2007 | 10:52 PM
ebluevette's Avatar
ebluevette
Default noise above 75
my car makes a weird moaning/drone noise also at higher speeds, but it only happens when my wife is in the passenger seat.
Seriously, it sounds like a wheel bearing, can you determine where the sound is coming from (front or back, left or right)?
Old May 10, 2007 | 11:58 AM
kevin40zx's Avatar
kevin40zx
You don't turn? Umm... I had a wheel bearing go in my other car and it seemed that when I turned and unloaded the bad bearing the noise stopped. Then when the car straightened out it made the noise again. Maybe find a highway with a sharp curve in it and turn the car. See what happens.
To weird noise when going more then 75 mph
