Anyone here good with Jeeps?
I'm getting really pissed off at mine. 6 months ago I had an intermittent low RPM (1500-2000) stumble. Did plugs, wires, cap, rotor and the problem was solved, the old distributor cap was kinda nasty and worn underneath, so it ran like a champ with a new one on there. The other day it started acting stupid again, and since I had a warranty on the wires I changed them again, and switched my spark plugs to a different kind. Nothing. Tonight I pulled the cap and rotor off, and they both had some corrosion so I ran to Murrays (gotta love 24 hour parts stores) and replaced them both. Still missing. Any ideas? When I pulled the plugs they still looked pretty new, too new almost. They should be golden brownish but these were still pretty white. What would you guys check next? It's a 99 with a 4.0, about 112K on it which for a 4.0 is nothing. I have noticed if I pop it in neutral it revs fine, but when I am in gear it accelerates goofy and jumps until I get above 2 grand, then it is fine. Then since I cruise about 1700-1800 @ 45 mph, it bucks and acts stupid there sometimes too.
Did you check for engine codes?
Have you thought about running fuel injector cleaner in it?
Another forum you could check:
www.jeepsunlimited.com
Good Luck!
Haaaaa,,, I just got a 98 Wrangler 4.0!
Two or three years ago, I wouldnt have given you 5 cents for a Jeep!
Now I have FOUR~
As for the 99, as recommended above,,check for codes. I would also check the CAT and make sure it is NOT plugged up. Next, check fuel pressure. If you dont have a hand held scanner for OBDII,, go to autozone and they will read it for free!
Mine was running very strange and I changed the plugs, wires cap and rotor. My distrubator screws were frozen in place so,,, I had to do some CUSTOME work to fix the distribuator housing. The tune up helped but, I did a seafoam treatment in the tank and down the TB and it runs a LOT better.
Im with you all the way on this one. If the post gets locked, PM me!
I have an 84 90, 91 and a 98. I purchased a 97 for my son to presuade him to graduate. It needed work (lots of work) and became one withe the Wranglers.
Theres a Jeep forum that works a lot like corvette forum. http://jeepforum.com/forum/forumdisplay.php?f=12
Please let me know what you find.
Oh,,yea,, one more thing. Do you know what the JEEP acronim stands for? JEEP = Just Empty Every Pocket
BC
One more thing; IN BEFORE THE LOCK!!!!!!!!!
BC
