Dont panic!!!!!!!!!!!!
Old May 6, 2007 | 06:28 AM
wettvette's Avatar
wettvette
Default Dont panic!!!!!!!!!!!!
Took the car 3 hrs out of town to a track where i spent 2 hrs of hard driving tight twisty corners with lots ofhard braking,was awesome. Then i headed for home 1.5 hrs into the trip my engine light on the dash comes on, oil and water temp were normal. i drive another 20 min to gas stop and turn off engine, then turn it back on and the stability control, abs and engine light come on ,the dic says service abs and stability control. i push reset to clear them and carry on , drive another 1.5 hrs to home turn off and get the same dic message. ileave it for a bit then turn the engine on and only the engine light comes on.
Can someone please please help me and tell me whats wrong
Ok i looked through the codes and there were about 10 H codes of that 10 one was an H C code 99-HVAC BO333HC
looked uo the code and it said Air Temperature Sensor Circuit.... ok so now what does that mean ?
Thanks for the help so far guys. It appairs the codes have nothing to do with the engine light staying on, any other ideas?
Im trying to find out as much as possible here, because there are no chevy dealers in New Zealand i guess thats the price you pay for importing a car they dont sell here
Old May 6, 2007 | 09:20 AM
corvettedoug's Avatar
corvettedoug
I would pull the codes for more details. Just hold down the "Options" button and press the "Fuel" button 4 times. Then you can scroll through each section of the codes.
Old May 6, 2007 | 01:18 PM
mickey_7106's Avatar
mickey_7106
Old May 6, 2007 | 05:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is everything that you need to know!
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Write down and post your DTC’s Then clear them ALL!
Sound effects are cool too! 
BC
Old May 6, 2007 | 08:54 PM
happa's Avatar
happa
Mine did the same exact thing, went off about 2 days later and havent came back in 2 yrs (knock on wood) Good Luck!
Old May 7, 2007 | 01:09 AM
Mikeceli's Avatar
Mikeceli
Old May 7, 2007 | 01:58 AM
wettvette's Avatar
wettvette
thanks guys ill check them soon and let you know how i get on
Old May 7, 2007 | 09:05 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The B0333 code is just showing that the outside air temp sensor has failed, this sensor is mounted up in front of the radiator on the right side of the car, if you crawl under the opening by the radiator you'll see the tip of the sensor sticking into the airstream.
Obviously this is not causing any of your fault lights though, it will only cause your A/C to not heat or cool properly.
Old May 7, 2007 | 02:44 PM
wettvette's Avatar
wettvette
[QUOTE=runamuk;1560146478]The B0333 code is just showing that the outside air temp sensor has failed, this sensor is mounted up in front of the radiator on the right side of the car, if you crawl under the opening by the radiator you'll see the tip of the sensor sticking into the airstream.
Obviously this is not causing any of your fault lights though, it will only cause your A/C to not heat or cool properly.[/QUOT
thanks
Old May 8, 2007 | 01:23 AM
wettvette's Avatar
wettvette
To Dont panic!!!!!!!!!!!!
