Fuel Gauge Problem Please help
Old May 6, 2007 | 10:13 AM
Allen S's Avatar
Allen S
Cruising
Default Fuel Gauge Problem Please help
When driving last night my fuel gauge suddenly went to E. When re-starting the car the gauge goes to F and and right back to E. The car has 1/2 tank.
Thanks.......
Old May 6, 2007 | 10:34 AM
ant21b's Avatar
ant21b
I had this problem cleaned all my grounds in the engine compartment (under the hood) and that fixed it. Might also be the fuel sending unit in the gas tank maybe its ground.
Old May 6, 2007 | 10:44 AM
G8rDMD's Avatar
G8rDMD
National Champs Gators 4 St. Jude '09
St. Jude Donor '10-'11
You may also want to try adding a bottle of Techron additive (can find it at auto parts stores). The sending unit in the tank can sometimes become dirty from lower grade gas and the Techron seems to do a good job in fixing the issue. Same thing happened to me and the Techron did wonders. Good luck
Old May 6, 2007 | 10:53 AM
trussme's Avatar
trussme
Default Sending unit sticking problem...
Thanks.......
Many have experienced your problem..including me . Techron additive by Chevron...available at all auto stores, will most likely solve this problem. You get you gas tank near empty, pour in the large size "20 gals." size of Techron....then fill up your gas tank with gas. After 2 of these Techron-added fill ups your problem should go away. Techron will unstick that sending unit & also clean those injectors. This fuel gage senario occurs mostly with Vettes that sit for long periods, than ones driven daily....or, could be the brand of gas you use. But, a bottle of Techron with every 3rd or 4th fill up will keep that sending unit freed up....Good Luck!
Old May 6, 2007 | 11:07 AM
Allen S's Avatar
Allen S
Cruising
Default Thanks
I am on my way to the store...... I hope ie works since I just got car and have a veru un-easy feeling since I do drive the every day. The prevoius owner put 2K in in a year.
I try not to put cheap gas in it.
Old May 6, 2007 | 11:23 AM
trussme's Avatar
trussme
Default There's your problem...
I am on my way to the store...... I hope ie works since I just got car and have a veru un-easy feeling since I do drive the every day. The prevoius owner put 2K on it a year.
"PREVIOUS OWNER"...did Not drive it enough to keep gas additives from gumming up the sending unit....they do gum up easily if not driven much.
Old May 6, 2007 | 11:50 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I am on my way to the store...... I hope ie works since I just got car and have a very un-easy feeling since I do drive the every day. The previous owner put 2K in in a year.
It is not the fuel, it is the brand of fuel you use. 93 octane is 93 octane no matter where you get it. It is the detergents and additives that a certain company may add to their fuel.
www.toptiergas.com is a good place to check. Its funny because Mobil claims to be the best in cleaning additives, but is NOT on the list.
The techron works well, I add 2 bottles every spring into my first "new" tank of fuel, after storage.
Old May 7, 2007 | 11:41 AM
C5 ChemE's Avatar
C5 ChemE
Why should we have to deal with this BS?? I've had my car in twice already to replace sending units, sensors, blah blah blah, and my gauge STILL goes to "E" NUMEROUS times per tank!
I'm going to bring it in AGAIN to get it fixed under GMPP, but in the meantime, I just reset the code and it fills back up.
I've run out of gas TWICE already with the gauge showing 1/8 left!
Car only sees Shell V-Power- so I'm not cheapin out here
Old May 8, 2007 | 04:23 PM
hihoSilver's Avatar
hihoSilver
I just had my sending unit replaced yesturday. Or actually, they replaced one of the tanks, due to sending unit failing. Same thing, I went up a steep hill, then gage went to E "low fuel" all of that sht. It was under extended warrantee. Would have been a $1200 fix.
Old May 8, 2007 | 09:40 PM
Nyvetteguy007's Avatar
Nyvetteguy007
Add Techron till it goes away...1 bottle (bigger bottle for 20 gal of fuel) per tank...after it functions properly, use every 2-3 tanks..you will never have a problem again...
Old May 8, 2007 | 09:43 PM
corvettedoug's Avatar
corvettedoug
Old May 9, 2007 | 12:49 AM
exstanger's Avatar
exstanger
I have a 98 coupe and the only time my fuel gauge had this symptom was the one time I used Shell. I have since used Chevron and have not had the problem. $.02
Old May 9, 2007 | 06:32 AM
trussme's Avatar
trussme
Default Shell....?
.....you are not the only one who has experienced this problem using Shell gas. Some time ago, info was published about an additive Shell was using that caused gumming/sticking problems with gas tank sending units. Shell has since remedied this problem, but many sending units were affected....so, there is probable validity to this. I used Shell fill ups (no Amoco's available) on a 1000 mile trip several years ago....and then let the Vette sit for 45 days while we settled into our new home. Weeks later, gas gage started acting up...read about "the Techron fix" on this Forum & solved my problem. I feel it is TWO things: 1.all gas has additives ...2.sitting in tank for long periods allows additive build-up on sending units (some stick worst than others)....and evidently Corvette sending units are more susceptible to this .......
Old May 9, 2007 | 08:23 AM
cruisemon's Avatar
cruisemon
To some extent it can be the fuel brand, but more often than not the problem stems from the fact that the C5 has two tanks. The passenger side tank is constantly pumped to keep the driver side tank full. When the passenger side pumps down and exposes the level sender for extended periods of time, fuel residue can gum up the sender and in some cases form deposits on the contacts and components.
And just a reinforcement of a tip mentioned above but maybe not stressed strongly enough - do NOT fill the tank first and THEN put in the Techron or Sea Foam. Put the additive into the car when both tanks are near empty. If the problem is severe, put in a double dose of the additive. The only way the additive gets to the passenger side tank is by putting the product into EMPTY tanks so that the blend is transferred to the passenger side.
For those who have Chevron stations nearby, this fuel has Techron in it from the pump. I think Texaco has it as well but can't remember for sure.
Charlie
Old May 25, 2007 | 08:09 PM
Allen S's Avatar
Allen S
Cruising
Default Thanks to all
I want to express my thanks to everyone. I used the Tectron and it fixed the problem.
Old May 25, 2007 | 08:54 PM
Nyvetteguy007
Great to hear it fixed your problem....
Old May 26, 2007 | 09:22 AM
99 vett babycar's Avatar
99 vett babycar
techron or Red Line injector cleaner
To Fuel Gauge Problem Please help
Old May 26, 2007 | 02:09 PM
birch64's Avatar
birch64
I bought my car used in nov. of 2003, I used BP only in my car. And last week I had this problem also.....I just put in a bottle of techron hoping this will take care of the problem...so I don’t think it’s the gas people use.....i think its letting the car sit and not letting the gas tanks go below a half tank once in a while. my car really never gets below 3/4 then i top it off, i think thats my problem.
Old May 26, 2007 | 05:31 PM
cruisemon's Avatar
cruisemon
Sulfur in the fuel makes deposits on the sensor potentiometer which detergents like Techron or Seafoam remove. Leaving the deposits out of the wet fuel lets the deposits harden. I don't think BP has a detergent comparable to Techron even though it is a good fuel. Adding the detergent to a mostly empty tank to be sure it is carried over to both tanks will help.
Charlie
Old May 26, 2007 | 05:57 PM
2KFRC5's Avatar
2KFRC5
Default 1999 - 2002: Service Bulletin: Erratic Fuel Gauge Reading (Reprogram the PCM)
Subject: Erratic Fuel Gauge Reading (Reprogram the PCM)
Source: Chevrolet Dealer Technical Service Bulletin
Number: 02-06-04-010A - (06/27/2003)
Models: 1999-2002 Chevrolet Corvette
This bulletin is being revised to add models and update the Correction and Warranty Information. Please
discard Corporate Bulletin Number 02-06-04-010 (Section 06- Engine).
Condition:
Some owners may comment about the fuel gauge intermittently indicating an empty reading and then
return to the correct fuel level indication.
Cause:
This condition may result when fuel blends containing aggressive sulphur compounds react with the fuel
sender assembly, which may result in voltage spikes being induced on the fuel level signal to the PCM.
Use of another fuel blend may reverse this reaction and return the system to normal operation.
Correction:
Reprogram the PCM with the new service calibration which is available in the June 2003, Techline®
TIS release sent to the dealers on 6/28/03. Use the TIS Version 7 or later data update.
