I changed to Mobil 1 at about 49,000, then have sixth gear grinding problems after 51,000 miles. I then tried Amsoil ATD, although Amsoil ATF will work also. I have over 103,000 miles on original transmission and clutch.
Appearently these transmissions are sensitive to dirty fluid. I don't understand why GM says you never have to change fluid ?
