Driver Window Pops Out at 190mph!!
Old May 6, 2007 | 06:00 PM
Vince99FRC's Avatar
Vince99FRC
Default Driver Window Pops Out at 190mph!!
I have had this intermittent problem in the past. I want to now fix it. When I am on a local track my window seems to pop out when I hit 190mph plus.. What is the fix for this?
Old May 6, 2007 | 06:15 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
just roll them down. Might be a little windy though.
Old May 6, 2007 | 06:38 PM
TM-Z06's Avatar
TM-Z06
Maybe you should limit your speed to 189.99mph
Old May 6, 2007 | 06:39 PM
TBZ06's Avatar
TBZ06
Default Local Resident
Vince,
I am also a resident of Valrico, FL. Sounds like your car has some great mods. If your out at any local shows I would like to see the car sometime. I have a 2004 Z06 which is all stock for now.
Old May 6, 2007 | 06:49 PM
Vince99FRC's Avatar
Vince99FRC
Originally Posted by TBZ06
Vince,
I was at the Vette Show yesterday. It was in Sarasota.. We can probably hook up sometime this week. I have some errands to do, but I am on vacation till the 29th..
Old May 6, 2007 | 06:50 PM
Vince99FRC's Avatar
Vince99FRC
LMAO!! I could have swore I read there was a fix for this issue..?
Old May 6, 2007 | 06:51 PM
torchvette10's Avatar
torchvette10
You're lucky it happens at 190mph! Mine pops out at 170 mph It is pissing me off. I am sure they is a way to correct this but don't know how. I willbe waiting for the replies
Old May 6, 2007 | 06:56 PM
Vince99FRC's Avatar
Vince99FRC
Tell me about it.. I might have to tape my windows b4 any high speed runs..
Old May 6, 2007 | 06:58 PM
KOZ's Avatar
KOZ
Adjust the window blow out clip. The black thing in the middle at the top of the window. It should be about 4mm from the glass when closed. You can bend it with taps from a rubber mallet.
-KOZ
Old May 6, 2007 | 07:10 PM
Vince99FRC's Avatar
Vince99FRC
-KOZ
I will try that. I have a rubber mallet.
Old May 6, 2007 | 07:21 PM
TheSandman's Avatar
TheSandman
i always wondered about how to fix this issue...
Old May 6, 2007 | 07:57 PM
JPEAK's Avatar
JPEAK
I was going to suggest to weld them shut.
Old May 6, 2007 | 08:19 PM
GreyGT-C's Avatar
GreyGT-C
i've only had my C5 to 140 and it does not inspire the kind of confidence needed to push it to that kinda speed.. What the hell have you done to your suspension/etc?
PS..... i've been over 180 in the RX7 that i have, so it's not fear of going that fast...
Old May 6, 2007 | 08:28 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
If your C5 doesn't inspire confidence at 140+, something is wrong with it. No hyperbole, just the truth.
Edited: unless perhaps you have a base suspension. I've never had one of those at speed, but at normal speeds the one I drove seemed pretty soft. Try at least a Z51 spec, Z06 is better still.
Old May 6, 2007 | 08:35 PM
ditty22's Avatar
ditty22
My car was rock solid at 180 the 5 times i had it going that fast
Old May 6, 2007 | 08:38 PM
Vince99FRC's Avatar
Vince99FRC
I have major confidence in my ride above 150mph. I have done minor suspension mods, but I was going 170mph when it was stock with just the Z51 suspension. The car is actually smooth up top. The only complaints are the window popping out some and the hood going up and down.
Old May 6, 2007 | 08:53 PM
superjet701k's Avatar
superjet701k
i have mine at 135-140 base suspesion f45 and its real floaty, good steering can definalty go faster only tact 4th gear . but i think i need sway bars car rolls also
To Driver Window Pops Out at 190mph!!
Old May 6, 2007 | 08:57 PM
2KFRC5's Avatar
2KFRC5
200 mph tape.
Or, the new improved:
Old May 6, 2007 | 10:02 PM
SUNNYD 95's Avatar
SUNNYD 95
SLOW DOWN !!!!!!!!!!!!!!!!!!
Old May 6, 2007 | 10:23 PM
TLewis4095's Avatar
TLewis4095
Scared the heck out of me the first time it happened....sounded like a jet was crashing into the pass. side! The clip bend should fix it.
